Question about Polaroid FLM-2011 Television
Connecting to a computer
The instructions say to use a VGA cable like with any other monitor but there's no way to plug it into the TV. So....... how do I hook the TV up to my computer to use it as a monitor?
  • Aunt Leen Jun 08, 2008
    It would have been more helpful to explain a PC to TV converter box rather than sending an advertisement to try and sell me one.
    I've been told it could also be done using s-video cables but there was no mention of that in your answer. Is it true? I don't want to spend another $100 dollars to hook it up I'd rather just buy another monitor.
  • 3 Answers
If you don't have a VGA input on your TV, you need to convert the signal using a device like this:
PC to TV Converter
Posted on Jun 05, 2008
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Rgb connection stopped working on laptop
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
How to watch computer on tv no hdmi on computer
As of right now your computer should be connected to your monitor using a vga cable. You can remove the cable from your monitor and plug it into your tv if your tv has the plug in. Also if you have a graphics card that has a s-video plug in than you can use that. If you have the s-video cable, just plug it into the port on the graphics card then plug it into your tv.
Picture of vga cable:
Picture of s-video cable:
Jan 15, 2012 | Toshiba Satellite L10 Notebook
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
We are trying to hook our TV up to our computer to use it as a monitor. What cords do we need to do this besides the normal monitor cord?
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Mar 21, 2011 | Sansui HDLCD1908 19 in. LCD TV
How do i connect my pc to my tv
Used the VGA cable came with ur computer monitor,used that VGA cable plug in VGA input it the tv and plug it other end to the computer video card.Used ur tv remote look for a input button pushes look for the mode computer signal in the tv like input 1,2, on.
Feb 12, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
I'm connecting to a tv with a VGA cable from my Acer netbook. My tv says No Signal. Windows makes the "ba dum" sound when I connect/disconect the cable, but under my display settings, it doesn't...
Don't forget that the TV source or input needs to be set to "PC". Once that is done turn the netbook OFF, then plug the VGA cable into the netbook and start the computer. The computer screen should automatically show up on the TV.
Nov 10, 2010 | Acer Aspire One PC Notebook
Can this be used as a monitor for a computer?
Sorry. The answer is you can't. Computers output comes as VGA [Video Graphic Arrey],or AGP [Advanced Graphic Protocol]; and it is not directly compactable with TV inputs. The computer outputs, Red_Green_blue and Horizontal and Vertical synchronisation signals seperatly through one VGA cable which goes into the monitor and there they gets processed and you see the image on computer monitor. Monitors are equipped with such circuits to process the same, whereas in the TVs there are not. Your TV is equiped with S-video connection and not have a VGA input connection.
You must buy a VGA to RGB converter for this purpose. It can be bought from the electronic market, and will have instructions and remote control of its own to control it. You must give the computers signal [VGA], to the input of that converter,with a [VGA to VGA] cable and from which the converter outputs R_G_B [Red_Green_Blue] along with an other output contains synchronisation signal, as described earlier, and will have directions in its manual where should it to be connected. Different converters have different confugurations for this connection, and it will be described in its manual. Ok.
Oct 29, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
Polaroid FLM-2011 Television Logo
113 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
