Question about Sony KP-51WS500 51" Rear Projection Television
Red lines faint red lines in a curve red shape sony kp51ws500
  • 2 more comments
  • coloradoboy Jul 13, 2008
    I have the same problem as ultragarcia. please help
  • tinobautista Aug 21, 2008
    red lines when goes on and couple seconds goen off
  • ikeb Dec 06, 2008
    need clear adjustment tv to bright white
  • Anonymous Jan 08, 2009
    Same problem. Techies tell me that the pic tube is about to go.
    Genius:
  • 2,920 Answers
You need to have the tv reconverged
Posted on Nov 04, 2008
I have a Sony, 54" Projection Screen HDTV that I bought in 2002. I believe it is a 1080i. When I am waatching TV, I notice that when the screen is mostly black, for instance a night scene, the black areas...
Confirm the actual model number as the one indicated in the title is not HD.
Some of these sets had bad picture tubes that on a black screen or blank video input may in your case show faint curved lines and or some color (red,green or blue) present in the background.
If this is the case there is a fairly simple way to attempt to adjust something for this--not in the customer menu but fairly easy to get at and try.
Most of these sets were KP51ws500, 57500 etc.
SD TECH
May 11, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Faint red lines in a curved arch like pattern
For this problem, what you have to do is here I found this solution: Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the bottom is the blue, red, and green adjustments (they should be labeled). All you have to do is turn adjustment screw slightly to the left(or counter clockwise) and it should clear right up. That should do the trick, Hope this is helpful. Please dont forget your rating.
Jan 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Red screen and lines, then TV shuts off automatically
Adjust RED screen drive down, or disconnect,unplug CRT board from red tube turn set back on if it plays without shuting off RED tube is shorted or video IC on CRT board is bad.
Jun 19, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Faint red curved lines on Sony KP 51ws500.Converged = no work???
Hi There!
This sounds like a typical problem related to a older CRT.
If you remove the front cover of the tv, you can then remove a wood panel. Behind this panel you will see a block (high voltage splitter) it will have 6 "knobs" on it, 3 will say focus, 3 will say screen.
They will also be labeled R - G - B
Put the tv on a blank input so you can see the lines clearly on a black screen  - Find the knob for red, and SLIGHTLY turn it down until the red lines disappear.
Dec 22, 2008 | Sony KP-51WS500 51" Rear Projection...
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDP-65WS550
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
or try this
Sony Too green,red or blue
Feb 06, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony -kp65wv600
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Convergence out; having problems realligining red lines
Check all six small,soldered in pico fuses under IC heatsinks..
rated at 3.15 amp = do not exceed.............let me know.....T.
Nov 27, 2007 | Sony KP-51WS500 51" Rear Projection...
The screen turns red after being on for about 30 minutes
or
Nov 10, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
115 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
