Question about MSI MS-6528 LE Motherboard
Jusb connection wiring
I need help placing the right wires in the right place with the usb "jusb"
The problem with the MS-6528LE board is that the JUSB1 connector has a nonstandard pinout which is undocumented in the manual; MSI tech support is no help. However, trial and error shows that one of the USB channels (even-numbered pins 2-10) is simply reversed:
Posted on Mar 05, 2010
    Genius:
  • 1,027 Answers
These are standard pin outs as you notice your pins on JUSB areupside down to this but the pin locations are correct if you start from the blank (missing) pin and work backward.
Posted on Jun 06, 2008
How do I get my Sentry Safe S3877 to open when one of the wire is dangling from the battery pack?
Check, you are connecting to the correct spot. That is the place the wire broke off.
It could be you only are using 2 or 3 from the four batteries. Then the voltage is always to low.
Then check you got the right batteries. Never use manganese (Zinc-Carbon) batteries. They don't have enough capacity and can start leaking.
Sep 27, 2014 | Horace Small HS2148 Mens Sentry Plus...
Tip
When you have messed up wiring your motherboard..
it is easy...
remember this your motherboard is like a children play house red for red, square for square.. if it is not compatible for the socket it will never be placed well..
you need to connect the following..
first your main power supply to your motherboard
it is very easy to see.. it is a group of maybe 16 wires in a plastic connector..you will connect it to your motherboard..
your processor power is a four wired in plastic connector but it is square in shape..
note: take a good look in each connector they have squares cirlce, etc shapes in each wires so don't force it to connect if it is hard to it means it is not for that socket..
this is the turning point..
your power button, reset button, pw LED, HDD LED,
maybe you know where it is placed,
but note the sequence.. pw button, reset, pw led,hdd led,
if not you can try to short the pins of *********** board so that you will know where the power button will be placed...
your usb and internal speaker has their own pins....
note: take a good look to your motherboard before you connect it, it may cause you some trouble..
take a look at the + ,- signs that is encrypted in the motherboard...
you have to the red wire is fore the posite and the black is negative..
i know it is compose of four wires but they are in one socket right...
your hdd connect it i know you know that how..
that's all..
on Feb 07, 2010 | Computers & Internet
Front USB wiring configuration on an Elite 661FX-M Rev 1.0 motherboard
This is the usual configuration of USB connection on motherboard.
If you have single cables (4 separate cables for each USB port), connect following wires in order to the right side pins from top to bottom.
+5V (1) P4 - (1) - You may have any number in place of 4 P4 + (1) - You may have any number in place of 4 GND (1)
On left side, connect
+5V (2) P5 - (2) - You may have any number in place of 5 P5 + (2) - You may have any number in place of 5 GND (2)
Jul 22, 2011 | Computers & Internet
I cannot locate where to put the usb cord for the printer
There is a spot under the scanner cover of the unit (under the glass). On the right side of the machine you will see a place for youre hand to lift open the scanner cover. One plugin is for USB cable and the other for Ethernet cable.
Also there is a spot for the wire to go through on the right side, a small grove to place the wire so that the cover closes properly.
(still under scanner cover) so it goes out the back.
Jun 22, 2010 | Brother MFC 490cw Color Inkjet...
Power and computer connection wires for Z43?
You will need a Plug-In Power Unit marked
“Class 2” and rated 30 V dc at
500 mA. and dependant on the type of connection either a USB lead or a parallel printer lead(Centronics).
Oct 29, 2009 | Lexmark Color Z43 InkJet
Marantz SR 4003, Cables in right place.PEAK light on?Help!
Disconnect your speaker wires at the receiver,then test if it does not "peak" the receiver is fine and you need to check each speaker wire. re-connect one speaker at a time and test until it peaks. then disconnect at speaker and test again. if it peaks, it's a bad wire, if it does not, check the speaker, meter it for a short. If you still need help, post a comment and I can help you some more.
Aug 08, 2009 | Audio Players & Recorders
ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
A neighbour happened to call in and popped the right wire in the right place and presto we were in business. Not sure what he did but it worked. thankyou. wal
Nov 15, 2008 | Dishwashers
Pioneer DEH-P7000BT Car CD/... Problem with installation of USB & microphone
The glovebox is the easiest. I managed to find a "hole" to run the cable through from the compartment to the rear of the head unit. Use a flashlight to help you find possible places to run the cable through. Either shine flashlight from glovebox into console or vice versa. Look for where light shines through to find place to run cable. Use a wire hanger to run cable through the hole if it isn't accessible by hand.
For mic, I just removed the drivers side A-pillar trim and placed wire in there. Attached mic to visor. Some wire is visible, but not much.
Aug 28, 2008 | Pioneer DEH-P7000BT Car CD/ MP3 Player
MSI MS-6528 LE Motherboard Logo
1,703 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
