Question about Philips Magnavox 51MP392H Rear Projection Television
Jack i have a 52 inch projection need to find out how to pull the front off to replace screen could u help me with this lil prob
  • Jose Ochoa
    Jose Ochoa Jun 06, 2008
    I have a magnavox tv 51mp392h/17 top and botton of screen can not adjust the convergente is no working, I need tochange the convergente card or part can you tell where i can buy these parts, or the phono for phillips same as magnavox co. thanks Joe
    Sergeant:
    Champion:
  • 330 Answers
You have to release the trim first,there are many small screws behind the trim
Posted on Jul 07, 2008
Rca tv is blurry
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
May 06, 2010 | RCA P52926 52" Rear Projection Television
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
Rca flashing the menu screen
Check the buttons on the front keyboard panel. Try cleaning them if that's no help replace the panel or the buttons.
May 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Off color
hummm i wonder if you may have lost one of your projection tubes... like red or blue.. that would be my first instinct and i would have to remove or at least get the screen loose enough to see if all tubes are lighting. tube replacement on these are somewhat difficult and expensive. 250 just for the part and prob another 250 for labor. but if its not the tube it could be screen control adjustment of focus pack.. so here hopeing.. Willie@fordtv.com
Mar 01, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52 inch TV (turn on problems and channels rolling) HELP!
Your set uses the 195 series chasis. The only thing I can think of which would make the channels scroll by themselves is a contaminated PC board and pushbuttons behind the buttons on the front of the set. This is usually the case when spray cleaner or some other fluid is sprayed or spilled on the screen, and it drips down onto that board. To prove this, remove the back cover and on the top of the main chassis, where the top of the picture tubes are, is a small PC board with the remote reciever and a couple of jacks. The smaller jack is for the speakers and the larger jack is for the front panel PC board. Unplug the larger connector which goes up to the front PC board and then turn the set on with the remote. If the set works normally, the front PC board will have to be removed and cleaned or repaired (or just leave the jack unplugged and work the TV from the remote only). If you do not have any experience working inside projection sets then allow a qualified tech to handle it for you.
Aug 30, 2007 | RCA P52926 52" Rear Projection Television
Philips Magnavox 51MP392H Rear Projection Television Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
