Question about Samsung HCN653W 65" Rear Projection Television
3d function...Samsung HCN653W
The 3 colors appear like in a 3d motion its annoyin.. can somebody advise on how to fix myself???
  • Samsung Master
  • 8,617 Answers
You need to replace both convergence ICs they are STK392-040 you can get replacement ICs at the following site and they will provide free instalation instructions with pictures so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 05, 2008
Samsung plasma tv has vertical lines
The most cost effective thing to do is just replace the TV. The cost to repair will be close to the cost of a new LED flat screen, they are very cheap now.
Aug 21, 2016 | Samsung PN51F8500 51" Full HD 3D Smart...
Has wavey lines and horizontal shadows and will not complete auto focus. It happens after the tv is on 10sec. Have adjusted and cleaned the picture tubes did help clarity but still has the problems
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2011 | Samsung HCN653W 65" Rear Projection...
My Samsung HCN653W 65-Inch Widescreen Projection HD-Ready TV has a 3d like picture when it has been on a hour it goes back to normal
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 05, 2011 | Samsung HCN653W 65" Rear Projection...
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Fixing colors and picture
There is 3 resistors you need to CK 2.7ohms, near ICs most of the time you will fined 2 of them bad.
Jan 10, 2009 | Samsung HCN653W 65" Rear Projection...
The TV turns on and off after a few seconds and repeats itself.
Hi.
Either the stk convergence modules or the vertical ic have failed.
replace the 3 parts and it should fire up again.
Nov 21, 2008 | Samsung HCN653W 65" Rear Projection...
Looks 3D
I had a repairman replace the convergence boards. The picture is fine now however red & green colors are messed up.
Nov 11, 2008 | Samsung HCN653W 65" Rear Projection...
Please advise if you would be able to guide me as to where i could purchase tv parts...
Hello MMJB,
Here are the link to purchase your parts.
674e151.gifhttp://www.partstore.com/Part/MCM+Electronics/MCM/LA7845/New.aspx
183b00b.jpghttp://www.partstore.com/Part/Matsushita/JVC/TDA6111Q/New.aspx
4509847.jpghttp://www.partstore.com/Part/Samsung/Samsung/HCN653WX/Samsung/Samsung/0502001230/New.aspx
Best regards
circuitcity
Jul 09, 2008 | Samsung HCN653W 65" Rear Projection...
CONVERGENCE OUTPUT I.C.
Nextag and eBay are turning up nothing for this model. In comparison to other manufacturer's prices, the quoted price is not "unreasonable." Projection TV repairs are certainly not cheap. Sorry.
May 24, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
77 people viewed this question
Henry  Thomas
Henry Thomas
