Question about Intel Motherboard
Can not power-on
Good day,,, I have a problem in my MSI PM8M-V motherboard. Tha problem occur after Ireset the CMOS using jumper setting JBAT1. the default setting (normal) is at pin1-2, I pullout the jumper & placed it on [in 2-3 to clear the CMOS, and after a second I placed it back to pin1-2(normal). Then I push the power button and i was astonished to note that the power doesn't start. And so I checked the power supply, power switch and all... but it's all OK. Please help me... is my motherboard completely bad? or still some keystroke in the keyboard to reset or something? or is it possible to restore or repair my motherboard using LAN card? or shall we say remote assistance repair using other computer?. Thank you so much...
    Scholar:
  • 119 Answers
If you Motherboard was working initialy then there should be no problems once you replace the jumper to the correct (normal) cmos setting, ensure that this is done correctly because this could be you problem. if the jumper is in the correct position and all you other hard ware is functioning correctly and still your motherboard won't power up then check that you memory module(s) are installed correctly as well as that they and the processor chip are all functioning correctly. if you have checked all these and you still have a problem then you will have you replace your motherboard as it could be burnt or damaged.
Posted on Jun 07, 2008
Clear CMOS Jumper JBAT
Unplug the power cord and remove the RTC battery,quarter size watch type battery, for 10 min's.Put the battery back in and power it up.that should clear the cmos
May 19, 2014 | Asrock 775S61 Motherboard
Motherboard msi 7610 ver 2.1
To reset the motherboard: set the dipswitches at OC_SW1 to ON-OFF-ON, then clear the CMOS Ram by setting the jumper at JBAT1 to pins 2&3 while the power is OFF. Wait fifeteen seconds,Then return the jumper to pins 1&2 and turn the power on. This will re-set you to the factory defaults. You will need to enter the BIOS and re-configure your hard disk. The manual can be downloaded at ECS's website at: http://www.msi.com/product/mb/P41TC31.html#/?div=Manual
Apr 18, 2014 | MSI Ms-7610 P41t-c31 Motherboard Intel G41
MSI PM8M-V Motherboard Beeping Problem
Hello here is the msi homepage:
http://www.msi.com/product/mb/PM8M-V.html#/?div=Manual
If you download the manual, you need adobe reader, to read the content.
The drivers is available here:
http://www.msi.com/product/mb/PM8M-V.html#/?div=Driver&os=All
Please select your windows system.
The files has to be unziped, before installation.
How many beebs comes, when you start the pc ??
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
The fault could be the power supply, the ram modules, or a faulty setting of a jumper, on the mainboard, or the graphic card.
Do you get the "blue screen of death" ???
Any picture on screen with fault code ???
One long beep, is the ram modules failing.
Try to remove the ram modules, and insert one, and try to boot.
Best of luck
Jan 20, 2013 | MSI PM8M-V Motherboard
Display on motherboard reads FF
THat is the "power on and first initialize CPU" halt code. Most often, if this error occurs, you have a bad CPU. You should also check the JBAT1 jumper to be sure it is installed and on the correct pins. If the CMOS is being held reset or does not have its power source the system cannnot initialize the CPU.
Dec 31, 2011 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
Video controller ( vga compatible ) required
Here is an official link for downloading the on board VGA drivers for MSI 865GVM3-V for windows xp operating system. In case thisd is not you op. system you can use this link to choose another one. Note that Windows 7 are not supported, if this is your case you have to try the compatibility option.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 15, 2011 | MSI 865GVM3-V Motherboard
Where is the clear bios jumper in my mis k9n6pgm-FI motherboard
JBAT1 is right next to the SATA2 connector.
Clear CMOS Jumper: JBAT1
There is a CMOS RAM on board that has a power from external battery to keep the data of system
configuration. With the CMOS RAM, the system automatically boot OS every time it is turned on. If you
use the JBAT1 (Clear CMOS Jumper) to clear data. Follow the instructions below to clear the
data:
You can clear CMOS by shorting 2-3 pin while the system is off. Then return to 1-2 pin position.
Avoid clearing the CMOS while the system is on; it will damage the mainboard.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/...
Where is jumper reset
The reset jumper is labelled JBAT1 (circled in red below). Pins 1+2 are jumpered/shorted right now, just turn the machine off, move the jumper over to short pins 2+3, wait 5-10 seconds, move it back to pins 1+2 and fire it back up. Have fun!
May 25, 2010 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I NEED DRAWING FOR THE FRONT PANEL CONNECTION
Download the manual for you're MSI PM8M-V motherboard from MSI; http://www.msi.com/index.php?func=searchresult&keywords=PM8M-V&table=download
You will need to download and install Adobe reader to view the manual. Download Adobe; http://www.adobe.com/products/reader/
Open manual to page 9. See Front Panel Connectors: JFP1 & JFP2. There is no need to connect JFP2's Power LED jumper, this is completed at JFP1. Each wire jumper coming from the case will have one wire color in common with all connectors except the speaker jumper. That common colored wire will be use as negative.
The speaker wire commonly as red is positive and black is negative.
Cheers'
Mike
Apr 22, 2010 | MSI PM8M-V Motherboard
I am getting 1 long beep and then 6 short ones
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Dec 03, 2008 | MSI PM8M-V Motherboard
Intel Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
