Question about Nokia N70 Cellular Phone
White screen Hi! I have N70 white screen problem I tried to go to one of the technician and change the crystal ic and lcd but no effect. I can on it and heard the txt. the technician told me about the RAP 3G. Please help.. if you have any contact number mine is 09284220001. tnx
  • rahulkhade Jun 07, 2008
    white display comes on display
    ya have have same problem
  • 24 Answers
Bring New LCD from Authorised Shope make Fit it properly.
Posted on Jun 13, 2008
  • 458 Answers
This is a general N70 problem, you need to format your phone, all your data stored in phone memory will be lost but phone will be okay. follow these steps
Turn it off, press and hold *key, 3numeric key and green calling key now while holding these keys, turn on your mobile phone.
Keep holding these keys and the word "formating" will apear on your screen.
dont let go until the nokia start up apears
This will solve your problem
My phone's screen white, calls are coming and going, if i restart the pone then text nokia shows a while than screen still white what hapen
If call and message tones possibly heard,display problem comes from LCD,some components of this parts is weak that's why it shows display a while when turning the phone ON.
If you can provide LCD part from any dealer or suppliers near you,this amateur video can guide you replacing LCD screen of your phone.
Another possible problem is the Display IC module which generate the display,base on our experience,this can be possibly replaced using hot air reworking station,this is the second option if LCD is still working at all.In this case,I may advice you to bring the phone to a mobile service center for display IC replacement,this is more complicated to work with.well,to give you an idea,take a look at this video on how technician replace this parts.
Good Day...
Sep 18, 2011 | Nokia N70 Cellular Phone
WHAT IS THE SOLUTION FOR N70 WHITE DISPLAY How to repair Nokia1100 phone when put the battery ,It doesn't ON, it is vibrating
hi, common problem with n70 white screen, i suggest you take it to a service centre, because it could be 1 of 2 problems, either the lcd is faulty, or, on the main board, there are 2 crystals that control the lcd, they need to be changed, but will be cheaper maybe just to buy a new phone,
as for the 1100, if it doesnt turn on and constantly vibrates, i have a feeling that the phone has liquid damage, and is shorting out.
Aug 27, 2010 | Nokia N70 Cellular Phone
Just white screen cannot get thru with calls. tried software but in vain i was told you need to change the PCB which cost about 600 to 700 rs.. the set will function.. pl advise where i can purchase the...
Hai, In my country, we do not change the main board, because the cost is equal to the price of a new, why you need to buy the main board under the warranty repair only the longest one month? whereas if you buy a new or used, it is more worthwhile. If you have tried to change a new LCD display screen, but the results remain the same, perhaps it is divided UEM ic problem, this happens because you always fall. ic is too close to the frame. hentakkan effect on the frame due to falls, may interfere with the original position, if the worst Solder balls under the ic off. If you are lucky. Try to heat the surface of the UEM ic, add Solder flux before the process is done. Solder balls when you get looked melted, press the top surface is a soft ic so it does not directly close to the surface of the board, as this can make Solder ball attached to one another, if you have a place to sell spare parts for ic, it is better there ic change is the new home you buy a new board. cheaper cost, but I do not know the cost of installation if you sending to your technician.
Aug 06, 2010 | Nokia N70 Cellular Phone
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
Nov 25, 2009 | Nokia N70 Cellular Phone
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
NOKIA N70 Screen problem
it is white screen on display or black?
white screen problem can come from the ASIP filter on the mainboard.
change the ASIP or it usualy called Display IC.
before you change it, try with other LCD.
why the IC Display easy to broken.
cause it placed near the backup bateray.
the bateray producing liquid and the liquid make the IC Display broken
Sep 23, 2009 | Nokia N70 Cellular Phone
N70 whitew screen dispay but good lcd
may be display ic has damaged. so u need to change that or if ic ok then u have to change ur display.
Jul 23, 2009 | Nokia N70 Cellular Phone
Nokia N70 white screen
solution 1> fit a new LCD,
solution 2> if lcd fails its the display IC's. 2 x crystal like ics on the motherboard, replace them or have them replaced and your phone working 100%
Jun 13, 2009 | Nokia N70 Cellular Phone
Nokia n70 whitedisplay
the display ic is of nd the LCd is ok,  so checjk the crysta l iC  o the flash,, i conclude maybe the crystal IC has the problem
Apr 26, 2009 | Nokia N70 Cellular Phone
Nokia N70
hi there, to solve your problem. must go to any nearest service center. cuz the problen for that is the hardware, the display IC. and it is mostly the problem for N70 cuz' the display IC is near to the internal battery. when the battery licks it go directly the IC. and that can damage the IC.
May 15, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
