Question about Toshiba TEC B-SX4 Thermal Label Printer
  • 254 Answers
Try ramclearing the parameters.
You have to send the firmware on top of the actual one
Posted on Sep 02, 2009
  • pkwc Sep 03, 2009
    In fact you need a special code to reset the password!
    You have to give me a very good reason to give you the procedure
Unknown bios password prevents bootup
Ah, those darned unknown passwords on second hand or stolen laptops, or where the kids go off to their new lives and leave you with the laptop you bought them for university :>)
  • Removing BIOS password on Toshiba Satellite Laptop - YouTube
    • 4 MIN
    • ADDED 2012-10-06
    Video embedded · This video will describe how to reset the BIOS password bug on a Toshiba Laptop. What you will need to make sure you do before getting started:
  • Reset Toshiba Satellite BIOS Password ' Find Password Heres a quick and dirty way to reset the password on the Toshiba Satellite A205 BIOS. Warning! You can only use these tips on your own Toshiba computer if you forgot ...
  • Passwords: setting and removing (for BIOS, Supervisor, and ... Passwords: setting and removing (for BIOS, Supervisor, and Windows passwords) ... If you forget the BIOS password, only a Toshiba Authorized Service Provider can ...
  • Jan 09, 2016 | Toshiba Satellite A205-S5804 Notebook
    Have a label with colours of gray and black. Toshiba B-SX5T printer does not print the gray colour very well at all. Shoppy print of areas on the label that are gray. Printer issues?
    You must either modify your graphics or try another driver ou driver options.
    Take care that this printer only print black dots and the grey is obtained by not printing all the dots.
    With some algorithms the grey color is not correctly interpreted.
    Sep 09, 2013 | Toshiba B-SX5T Printer
    How to send printer commands to TEC SX5 printer
    A lot of printers you can put special commands in a text file and just send it as a print job. You will want to consult toshiba for commands. Also lots of printers accept commands via telnet. You can use putty to telnet to the printer. Also many printers have web interfaces to configure them.
    Dec 18, 2012 | Toshiba B-SX5T Printer
    Hi i have forgot my parent password on my home access toshiba laptop so now i cant do anything how do i recover this or put my laptop restore please help
    A Windows password reset bootable disk could do all the job for you, it can reset your forgotten or unknown Windows password safely and quickly without login, you can create one with the tool Windows Password Breaker, then use it to reset your password.
    Feb 27, 2011 | Toshiba Computers & Internet
    We've a problem with our TEC printer B-SX55. Sending a job via parallel interface only results in an error message showing up: XS;I,0001,0012C5 Can anyone tell me what to do to get it up and running...
    This type of error message usually means a command error has been found in a command received by the printer. 16 bytes of the command error, hence the XS;I,0001,0012C5 message. It starts from the command code, XS.
    I am not sure of all the command codes but I would suggest starting by re-installing the printer driver.
    Dec 17, 2010 | Toshiba B-SX5T Printer
    I am having problem with sending commands to printer. i copy the commands in user manual on the "send printer command" section. But the printer no any response.
    I would certainly check all data connections, if everything is ok, then make sure that the printer is in the correct setting for receiving this data
    Jun 25, 2010 | Toshiba B-SX5T Printer
    My toshiba tecra8000 laptop displays toshiba logo for 1 second and then it displays password.Bios batteries have been removed.code no of flash eprom on mother board is unknown tome.If I get the code no of...
    The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
    You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector this is a picture of the finished dongle
    Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
    Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
    Mar 09, 2010 | Toshiba Tecra 8000 Notebook
    How to share printer B-SX5T , under Windows XP
    Please follow the below steps -
    1) Go to Start and click Control Panel. Control Panel Window will appear, then double click Printers and faxes.
    2) Printers and Faxes window will appear. Right click the printer you want to share, then click Sharing…
    Note: Make sure you've enabled File and Printer Sharing for Microsoft Networks on network card's properties.
    3) Select Sharing tab and tick Share this printer to share the printer. You can type in a new name in the Share name text box to change your printer name on the network, however this will not change the printer name on your computer. Click Apply.
    Note: If the other users using different version of Windows to access your printer, they will need to install printer driver themselves. You can help by installing additional printer drivers on your Windows XP, so that the printer driver will be installed when other users access the shared printer with different version of Windows. Click Additional Drivers, tick additional driver you would like to install. You will be prompted to install those additional drivers after clicking OK.
    4) Once you have shared the printer, you will see there is a hand supporting your printer.
    Please post comments if you need more help or information...........
    Good Luck!!
    Dec 29, 2009 | Toshiba B-SX5T Printer
    Euro Symbol Printing
    0128 is not a recognisable sysmbol Go to the Toshiba web site and the tech Support team- evidently there has been an error in the printed instruct as to the symbol number.
    May 21, 2007 | Toshiba TEC BSX5 Thermal Label Printer
    Toshiba TEC B-SX4 Thermal Label Printer Logo
    683 people viewed this question
    Top Toshiba TEC Office Equipment & Supplies Experts
    Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
