Question about Kenmore 24032\24036 Top Load Washer
Washing maching won't continue cycle
Loaded wash, it filled to correct level then nothing. No agitate, no spin, no drain nothing. took laundry out, emtied water by hand..tried again..filled up no problem but stil nothing? What the heck? Any help on this?
  • 2 more comments
  • wtpowell3 Jun 08, 2008
    Same Problem. I tried turing the dial to cycle the wash but nothing happens not drain no spin no agitation. The washer only fills. Is this a motor issue?
  • Anonymous Jun 09, 2008
    it will wash but want drain the water
  • Anonymous Aug 12, 2008
    fills with water....that's all.....won't agitate....no sounds, no clicking, no nothing.... Got any idea how to troubleshoot or fix this??? Richard...
    oh, this is a Kenmore Series 80
    I have taken the clothes and water out...start over....same thing, nothing happens after the tub fills.
    Kenmore Series 80 washer.....fills with water, but won't agitate...took clothes and water out tub....started over....same thing, nothing happens...
    Can you help? Thanks Millspops
    Guru:
  • 1,342 Answers
Check that the front door or lid interlock switches are operating. If they are not, the machine will not start. It is a very common cause of non-operation, and simply opening and closing the door will usually clear the problem if it is just intermittent sticking.
Posted on Jun 06, 2008
  • Georgia B
    Georgia B Jun 06, 2008
    Washing-machine-repairs - The washing-machine fills with water but does not start the washing cycle
    1. The water level sensor or float switch may be faulty. If the
    unit does not sense that the water is at the right level nothing will
    happen.
    2. When the water filling rate appears very slow, the inlet
    water filters may be clogged. Although not that common the inlet
    solenoid valve can jam and only partially lift.
    3. The cycle timer or program circuit board may be faulty
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
106 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
