The rack and pinion gear on the focuser for a meade ds 2000 telescope got stripped. I can't find replacement focuser online for this type of telescope.
Eyepieces DO NOT have threads -- they slip into either the focuser or the diagonal depending on which scope type you own.
You MUST MEAN the focuser is stripped-- a new 60mm focuser assembly will cost you about $20-$30 if you can find one. Call Meade first here: http://www.meade.com/support/index.html and see if they will sell you one. If not look around this web site:
It might be easiest to see if someone is selling one on Craig's list or ebay. You might be able to find one used where the telescope is OK, but the motorized drive is broken and replace the telescope.
Here is the contact information for Meade:
Contacting the Customer Support Center
Customer Support representatives are available to handle your calls and letters regarding any Meade product 7:00am to 5:00pm Pacific Standard Time, Monday through Friday, excluding holidays. To contact the Meade Customer Support Center, please write, call, or fax. Our information is as follows:
Meade Instruments Corporation 27 Hubble Irvine, CA 92618
(800) 626-3233 (U.S.A. Only)
You could try calling them and see if they will sell the part you need for the focuser. The focuser is called a rack and pinion focuser. From your description it is hard to know if it is the long linear gear on the draw-tube (the part that holds the eyepiece) or the gear on the shaft of the focusing knob. You will need to be able to describe that to them.
I hope that helps.
ds-2000 refers to the model line of the scope. ds-2130 the 130 refers to the diameter of the objective lens in mm. I have a ds-2114. Where the objective lens is 114 mm in diameter. as far as the manual goes everything else should be the same.
