Hi!!
The Blower Motor Resistor also called Manual Temp. Control resistor), is fried, replace. The price with floor console $25 and without floor console $65. here is a pic.
the resistor is located on the blower motor housing, fastened by two screws. It is the part where the electrical plug connects, the plug on the pic. goes to the blower motor.
A HELPFUL - 4 THUMBS rating for this solution would be greatly appreciated. Thank you for using FixYa.
The problem is the blower motor resistor, it controls the speeds, high speed bypasses the resisitor which is why it only works on high.
Replace the blower switch mounted on the heater control panel for the high speed works off the high blower relay which is working fine
SOURCE: air condition fan only works on high speed, no low speed
You have a bad blower motor resistor. This is located under the dash close to the blower motor itself
SOURCE: 2006 silverado 5 speed heat, the high speed is not
The switch, high blower speed relay or the wire harness at the blower motor has gone bad. The highest setting 5 has no resistor, so the blower runs on high but the high current flow ends up burning up the switch's contact on that setting or the relay and may be the resistor wire harness at the blower motor has gone bad. Common would be the switch it self, if the switch is good. Then it's going to be the blower relay or wire leads at the speed resistor by the blower motor under the glove box by the passenger leg compartment. Keep me posted, be glad to help you get your Silverado running 100% again soon.
Testimonial: "thank you"
