Question about Kenmore Washing Machines
The water wont drain from the tub. and it will not spin
  • 725 Answers
Is the drain pump working? have you cleaned out the drain trap? let me know and I can help
Posted on Jun 05, 2008
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
My Kenmore elite wont drain. every time it starts the cycle it stops spinning because the water wont drain. we think its clogged but we don't know what to do.
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine will not drain. water wont drain
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 12, 2009 | LG WM2016C
Water is full in washer and wont drain or anything??
mostly drain problem or spin problem. It won't drain If your washer won't drain, check these:
May 08, 2009 | Washing Machines
Hotpoint aquarius WMA40S Drum wont turn at all
the drive belt needs to be replaced. if you take it to a home depot or a lowes they will replace it at a cheap price. thank you for using fixya
Feb 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine shaft wont move
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washer wont drain water
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
Washing machine
hi friend,
hoses
May 18, 2008 | KitchenAid KAWS850L Top Load Washer
Water wont drain
hi friend,
hoses
Mar 27, 2008 | Hoover H140E Front Load Washer
Washing Machines Logo
29 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
