Question about Dell Inspiron 8500 Notebook
Dell 8500 loading issue
I have a dell inspiron 8500, it crashed on me, now it wont even load up.
all the lock key leds will flash, power button will come on, then thats it.
if press the power button, it will just turn off.
  • 191 Answers
I let you know one simple thing
run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a hard drive diagnostic
i will be able to help you out in the best possible way if you provide me with an error code
and if you don't get any error and all tests pass
then you have to take the system back to day one or use Operating system cd to reinstall the operating system
provide me the service tag for your system
your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number
i'will be able to provide you links and instructions to reinstall operating system and can provide you links for drivers to be downloaded and installed.
Posted on Jun 07, 2008
  • Dell Master
  • 1,183 Answers
The symptom that you have written suggest it to be a motherboard failure. To determine the same, follow the steps in the link below
http://tinyurl.com/6ccrbx
Thanks
Mandeep
Posted on Jun 05, 2008
I turn on the laptop the dell logo boots then the screen goes blank a padlock is illuminated on the panel . What is going on?
You have 3 padlock LED's. They are as follows.
icon_9.jpg Turns on when the numeric keypad is enabled. icon_a.jpg Turns on when the uppercase letter function is enabled. icon_scroll.jpg Turns on when the scroll lock function is enabled.If you don't get a display when Windows tries to load then you probably have a video driver issue. Try to load Windows in safe mode by powering on the laptop and tapping the key. If it works then your video driver might be corrupted or your video circuit has a problem.
Feb 07, 2011 | Dell Inspiron 1525 Notebook
The lock key is on and that freezes my word document
I have a Dell Inspiron 6000 pv and I am not sure what you mean by the "lock" key. There are 2 lock keys on the computer: Number lock - which doubles as the Scroll lock when combined with the "Fn" key. Either of these can be toggled on or off. To enable or disable, simply press the key. If the lock for Caps or Num is on, the led just left of the power button will be lit.
On the Inspiron 6000, behavior for the NUM lock can be set in the system set-up. I am assuming the issue you are having has to do with how the lock is configured in the setup. Try adjusting the behavior to see if this helps fix your problem.
Apr 02, 2010 | Dell Inspiron 6000 Notebook
Will not power on once chager is plugged in lights flash three times but there is nothing
what lights flashed? is it the LED locks or the battery light? try to run PSa. press andhold the fn key and pree the power button and release button at the same time when you see the dell logo screen
Oct 01, 2009 | Dell Inspiron 1000 Notebook
My Dell latitude E6400 does not power on
Try memory modules individually. See if any change.
Also post whether the Lock LEDs are solid or flashing
Aug 08, 2009 | Dell Inspiron E1505 Notebook
Dell M1530 wont turn on
A flashing ON ON Lock LED sequence is indicative of a failed Motherboard
Jul 03, 2009 | Dell XPS M1530 Notebook
Inspiron 6000 wont load up
Does the keyboard respond to any of the caps lock or numlock buttons when pressed ?
Mar 02, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 8500 doesnt continue boot up
is the crackling noise constant?
if so, your hard drive is lockup on the bootup. you have to get a new hard drive.
or you can try to reformat the hard drive, but I don't think that will help.
Jan 03, 2009 | Dell Inspiron 8500 Notebook
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Notebook System Crash
Hey there SeanJohn79, have you tried hooking an external monitor to your laptop. You can move the video output back and forth, from external, LCD + external, LCD using Fn + F7. Hopefully this will allow you to see the necessary info for diagnosing the problem. Good Luck. Keep us posted! In case you are not aware, these are some display related key functions:
Fn + F3 = turn off lcd
Fn + F8 =Switch computer screen size
Fn + F12 =Hibernation mode, power for 4 secs releases.
Fn + F4 = Standby mode, press Fn key to return to normal
If you haven't tried switching some of these, give it a shot.
Jan 31, 2008 | Dell Inspiron 8500 Notebook
Open Questions:
Dell Inspiron 8500 Notebook Logo
73 people viewed this question
Alun Cox
