Washing Machine, Simpson Brand, Esprit 750
Hi, I live in Australia. I would like to ask some advice. I have a Simpson Brand, Esprit 750 Model 22S750, nearly six years old. It has been playing up for more than six months now. It will sometimes agitate and sometimes not. It will sometimes spin and sometimes not. It may be working (agitating or spinning) and then all of a sudden stop working. Water always fills up and pumps out, with no problem. The selector dial always ticks and goes around. The on/off clicker for the lid seems to be working fine. More recently though the machine also started making a terribly loud noise when it spins, I don't know if that has anything to do with it. I have also found that if I turn the selector dial really fast around whilst in the on position, sometimes starts the machine working again, but not always. Sometimes I leave it for a day and then it will work again. In a family of 2 Adults and 6 kids my machine is really important, and if I could fix it myself, that would really help. If anyone would know definitely what this problem is and could let me know which part needed changing I would be most greatful. Yours Sincerely, Angelina.
  • Angelina AL Kaaby Nov 15, 2011
    No I went and bought a quality washing machine a Miele front loader made in Germany not China-made. Sorry couldn't be more helpful.
Hi Angelina
I am having exactly the same problem. Did you replace the timer, if so did it fix the problem?
Thanks,
Sheryl
Posted on Nov 15, 2011
    Novelist:
  • 177 Answers
Angelina, price out a replacement timer vs new washer. You maybe better off buying a new Kleenmaid Toploader.
Posted on Jun 07, 2008
Wires on motherboard, which way around do the blue and brown wires go to the water level switch? Simpson 22s750 washing machine
There are more than one model of the 22s750, you need to give the full model number. All of the 22s750 models I have seen have wires on plugs. The plug goes in to the water level switch and the other end has a plug that goes on to the circuit board. Do you have seperate wires or have you pulled them out of the plug. Give the full details if you want help.
Oct 12, 2017 | Simpson Washing Machines
Hi, got a Simpson esprit 750 washing machine. Pulled power cord out from main board when moving it. Can you tell me where the brown and the light blue wire reconnect please. Earth is easy.
They go on to the timer. On the end of the timer is a row of terminals with other blue wires on them. They are all the neutrals, put the blue wire on one of those end terminals (any one that is empty)
There is a terminal in the centre of the timer marked A. That is where the brown live wire goes.
Jul 08, 2017 | Simpson Washing Machines
My washing machine spins but doesnt complete the spin cycle
does it drain all the water out/ If not then check your pump filter.
Oct 04, 2014 | Simpson Esprit 750 Top Load 7.5kg
Simpson washing machine will not fill with water. Epsrite 750. Hoses are fine, water pressure is fine. Just a dribble goes into the tub
Most hoses have a filter/strainer at the faucet end. This can get clogged. Remove from water source, check and clean.
Sep 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Main power flicks off when starting my simpson esprit 750 washing machine
Hi just read your posting,Now there are two types of Simp esprit,Is yours a top loader or a front loader? Does the machine trip the fuse when you select the spin cycle or only when it starts to fill?Have you tried putting it on a spin cycle?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Aug 28, 2010 | Washing Machines
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Washing Machines Logo
1,224 people viewed this question
Top Washing Machines Experts
