Question about Philips Magnavox 51MP392H Rear Projection Television
Sound but no picture.
Where do I find the Transitor to test and see if this is the problem?
  • Philips Master
  • 3,459 Answers
This may be the same IC that goes out all the time. Symptoms vary. Check www.magnavoxhelp.com for repair kits.
Posted on Jun 29, 2008
Tedelex tv makes a clicking sound and does not want to go on
test the horizontal transitor with ur multi meter if it is bad replace with thesame number but if is not bad then u replace the LINE TRANSFORMER with thesame number
May 30, 2015 | Televison & Video
My Zentith D60WLCD has a green tint
some transitor is gone bad,you better send it for repair
May 19, 2008 | Zenith D60WLCD 60" Rear Projection...
I have sound no picture
No sound - no picture ? that's mean no power at all ? check fuse and power supply - mostly transistor faulty in primary section or the BU Transitor in the high voltage section
Oct 28, 2013 | Hitachi 36FX48B 36" TV
I have no picture but sound
Hello
Check the LOT [Horizontal Output Transformer, and horizontal output transitor of the set.
Mar 14, 2012 | Televison & Video
My RCA 27V530T has sound bu t no picture. Could this just be the picture tube?
Hello
There are many reasons for this fault, and picture tube is one amoung them; but a very rare case. Normally, for all picture tube based TVs, short in the windings or the LOT [Line Output Transforemer] is a normal case. If this occures, there will be no picture or screen at all, as all voltages to the picture tube, including its filament voltage are derived from this transformer. Check this first. If it has faulty, the drive transistor [horizontal output transistor] will also will get leakey. First check this transistor. If found leakey, replace it with same type and number. Switch ON the set for a short period of time, say 5 seconds or so, and check the heat of the replaced transitor by touch, after unpluging the set from AC mains. It can be some heat with this transisotr, but it should not overheat. If it overheats, make sure that the LOT said above is damaged, and should be replaced with same type and number. All these components can be bought from open electronic spare part selling shops at your town. You can do this work by yourself at home, provided must have sufficiant testing and soldering equipments; and a sound knoledge in electronics.
If you don't ahve these, get the TV repaired by any experienced service technician, of by the authorised service center for RCA at your town. OK.
Oct 12, 2011 | RCA 27V530T 27" TV
I have a Cambridge audio turntable which looses sound quality about halfway through record, as though it looses one of the channels (on the right hand side). I've tested the speakers, the amp, even had it...
Might be a weak relay or transistor in that channel, they both will stop and reset when overheated. make sure you're ready to test it when it does this again, this may help you locate the bad component. I'm leaning towards the transitor, because they also amplify sound signals in radio frequency.
Oct 06, 2010 | Cambridge Audio Azur 340A 2-Channel...
I have a 32" Dynex flat screen DX-L32-10A and I turned it off and later tried to turn it on, ther is no sound or picture, I only have a blue light on some one please tell me what to do0
It could be either bad capacitors which are noticable or bad transitor not noticable. It is in short protect mode to stop it from possibly burning.
Jul 04, 2010 | Dynex DX-L19-10A LCD TV
Blinking light without picture on Toshiba 57H81
No good news here sorry!
Power board and video X and Y boards need intervention If you are going to take a look you will find that one or even both boards have blown capacitors and burn marks along the transitor
You might be able to claim it as fusion on your insurance policy ( parts only usually) but thyat at least is some relief
Please rate our help to kepp the FREE service online ++++
Aug 31, 2009 | Toshiba 57H81 57" Rear Projection...
Black screen
you mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Sep 14, 2008 | Orion1934 19" TV
No video signal ,flyback lines on my 29pt philips
help is here. back off that screen control tell them lines go away.
you have these things working Powersupply, Vertical, High voltage, sound, leaves video problem , go the the video circuit on schematic and find the video out transitor or ic or whatever they use, check to see if proper voltage or better yet see if got video with a scope, I see allot of shorted video out transistors.
also check and see if you can inject video with a vcr out to the tv in.
Jan 02, 2008 | Philips 32PT6441/37 32" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
