15 to 20 PSI, using a 1/4" drive ratchet with the corrcet socket, you should get it right by just using your wrist to tighten the bolts, watch as you do this the gasket will slightly move. enough torque. seal your new gasket to your pan with a thin film of silicone sealer, let set-up till dry. Put a film of wheel bearing grease on the flange of the tranny and install the pan, the grease will not leak and if you need to remove the pan again it comes off easy.
