Question about Maytag Neptune MDE5500AY Electric Dryer
Neptune MDE4000Ayw squeaking when running
Does this have a belt that could be causing this?
  • Anonymous Jan 03, 2009
    squealing while running, I took it apart and found the tub roller on the right side worn and making rusty fine dust, you can see this in the bottom of the dryer base pan if you look with a flashlight on the right (or left) below the back wall. the axle pin does not look to be removable, but the roller is. I lube it with hi-temp heavy grease, but apparently it does not last, most shops tell me NO grease. So it's time to replace the roller, it's just a little too loose. Good luck.
    Genius:
  • 1,224 Answers
If its squeaking it means that in wants to be grease or lubed
all mechanical devices need some form of maintence to run properly lube the motor the drum the track wheels but not with wd40 use appliance lubericant or call your local maytag man to come out and do routine maintenance on your neptune
also to the guru if there was a foreign object stuck between drum and body it would be like throwing a monkey wrench into a clock towers gears it would slam to a hault so i dont believe in the object stuck theory
Posted on Jun 05, 2008
  • Christophe Thompson
    Christophe Thompson Jun 05, 2008
    my advice is free and you dont have to rate me this is totally at your descression if this info helped you in any way
    President:
  • 1,314 Answers
It has a belt and could be but it also has rollers that the drum sits on id suspect one of theese or a foreign object stuck between the drum and the body if you e mail me at b4829@yahoo.com and give me a good rating then ill reply with tech info spefic oh ill reply any way just send me the model number lol
Dryer sqeaks while it's running
This could be the result of a loose/worn belt, or worn drum roller bearings. Is it a constant squeal or a squeak......squeak.........squeak, basically in time with the RPM of the drum? If that is the case, get new drum bearings. If the former is the case, get a new belt.
May 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer (MDE4000AYW) making a sorta grinding noise when the start button is pressed then the drive motor starts up & the grinding stops. It sounds like a starter or transmission problem but I...
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
May 04, 2011 | Maytag Neptune MDE6700A Electric Dryer
My dryer squeaks model #mde3600ayw
Many reasons for this to happen. First the seal surrounding the drum to the front panel maybe dirty causing this squeak
In the other hand most squeaks are caused by the dried up bearing inside the roller for the belt tensioner. If so replace the belt and tensioner pulley for the belt gets stretched by a worn pulley and will break eventually too
Apr 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
It is a mod MDE4000AYW. How do I put the belt back on?
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 08, 2009 | Maytag Neptune MDE6700A Electric Dryer
Maytag Neptune clothes dryer Model# MDE4000AYW Noisey squeeking sound. However, after a few minutes when it heats up, the sound goes away.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
trxcvhj
Jul 05, 2009 | Maytag Neptune MDE6700A Electric Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
568 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
