Panasonic DP-C262 Copier
I have a Panasonic DP-C262 copier, I have an error message indicating that I need to have the "Fuser Belt Unit" replaced.
I would like to know if that's something that your company can replace, if so, how much does it cost?
Thanks,
Katie Walker - (310) 678-1266
  • sipichh Aug 20, 2008
    I need to replace the fuser belt. Where can I purchase this unit and who can I call to install this. I an in the southwest suburbs in Illinois.
    Guru:
  • 389 Answers
This costs around $300US, only you quite do not follow to change whole block. He wholly can be repaired, moreover if it is indicated fault of the stove, that this means that came out of building lamp,or thermo fuze or thermistor, as far back as stove change the rubber gross and gross teflon, but absolutely not without fall you will need its change. Return in service, this wholly part fault. Good luck
Posted on Sep 21, 2009
How can I solve a service 12 error
Call Service 12 means that the color motor rotation detection signal (LD) does not go Low.
After the LCD indicates this error turn the power off/on & perform the motor test by pressing the MENU, #, 9000, *556 and press 2 & set buttons. See if this helps you with this issue.
May 24, 2014 | Panasonic DP-MC210 Color Copier
The lcd display an error code ....E04-01...and i need to get into service mode to clear the message..thanks help please
Did you make a repair or replace the fuser and need to reset the code?; Because if you didn't fix the problem, you'll still get the same low fuser temperature error code.
Press <function>, <original size (ledger)>, <3>
to enter service mode, go to F9-05-04 (RAM Initialize, fuser reset, power off/on)
If the E4-01 error code returns you have a defective thermistor/thermostat.
Nov 22, 2013 | Panasonic WORKiO DP-C262 Printer
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
PANASONIC DP-C262 COPIER IS SAYING THERE IS STILL A PAPER JAM AFTER IT HAS ALL BEEN CLEARED
the diagram will show where it is but refer to user manual. if no paper then a sensor has become dislodged and will need to be reseated
Jan 09, 2010 | Panasonic WORKiO DP-C262 Printer
Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
May 16, 2009 | Panasonic Workio DP-3530 Copier
How to change a drum unit on Panasonic PD-C262?
It shold be a round cilader that should be the toner which is in a slid out drow which shold be in the may compartment of the printer. You will need to slid it out pull the toner out and place a new one in and firmly slide the draw back in.
May 01, 2009 | Panasonic WORKiO DP-C262 Printer
Fuser belt unit dp-c262
When making copies, there is line on the copies. How do I resolve this issue?
Katie
Apr 09, 2008 | Panasonic WORKiO DP-C262 Printer
359 people viewed this question
k24674
