Question about Frigidaire FRS26R4A Side by Side Refrigerator
Top Shelf Freezing
I have the Frigidaire FRS6L9EFSS with the same problem. It is under warranty. I've had 2 temp control boards replaced, and I STILL have the problem. The original unit would intermittently stop cooling, and the last 2 (replaced in the last week) both get stuck on 32 degrees or colder. I can punch up the temp, but then it quickly goes back down again. Could the technician be wiring the part improperly, or does Frigidaire really have that lousy a quality control on their parts?
  • robert samples May 11, 2010
    where are you getting 32degress freezer or fridge
    President:
  • 1,314 Answers
Look guy i dont know what you mean by temp control but they are supposed to replace the whole control assembly it comes as a kit it includes the temp control the adc control the damper door assembly now on theese models there was a promblem with the adc automatic defrost control and the damper assembly building up ice od the door jamming it open so it couldnt close when it was supposed to in the new kits a heater has been added to keep the ice melted so the door closes when it should the freezer does all the cooling for all units the fridge is controled by a damper door which its control operates if ice is stopping the damper door from closing dont matter which control you replace not going to help
Posted on Jun 05, 2008
    Genius:
  • 1,224 Answers
Ok heres something i learned not to long ago about top shelf freezing if you put your more moistend foods up closer to top shelf it will freeze the top half of your freezer the moistend foods with liquid or waters needs to be closer to the bottom
this was WoW to me never knew that when someone mentioned it too me
they also state let freezer thaw down and place foods accordingly by moisture content in the freezer this will keep freezer running accuratly for a long time
try this see if this works for you im sure its this and not actually a problem problem give a 2 week test with freezer rearanged accordingly
i hope this information has helped someway
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Dan, I have a Frigidaire Side by Side refrigerator model number ffhs2611lwb. The ice maker has not been making ice on a regular basis.
This sounds like you are responding to someone in your original post?
Please post as a comment in that original posting as 'Dan' is unlikely to see it. Fixya gets 1000s of questions a day!
Andrew
Moderator.
Oct 07, 2015 | Frigidaire Refrigerators
Items freeze on top shelf of refrigerator. All temps are per factory specs.
If it is only freezing on the upper shelf then you will need to replace the "air diffuser". It is not closing when the refrigerator temp is reached. Here is the part to order.
Nov 05, 2012 | Whirlpool GSC25C4Ey Side by Side...
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
My fridge is freezing things on the top shelf
meaning you have a uncontrolled compressor it run continuously without monitoring the temperature, The Temperature control or Thermo control switch. will switch ON the Comp. untill the preset temp. is obtain then Sw. OFF if the temp is out of preset value.
Jun 07, 2009 | Refrigerators
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Frigidaire Gallery Series range/oven showing an F-10 error code on the display. Model# GLGF376D (S). Top burners seem OK, but the oven temps are going crazy. Unit is 2 1/2 yrs new. Does this code mean that...
Service tech came the next morning (Nov.26th). The sensor tested out OK. He said that the control board needs to be replaced. Unfortunately there wasn't one available for this model - he had to order it, and he'll be back next week. The good news is that my lovely wife had purchased an extended warranty - so it appears that all parts and labor is covered. We all ended up eating out for the Thanksgiving holiday, and no- the restaurant bill wasn't covered by the warranty. I'll keep you posted on the control board replacement.
Nov 25, 2008 | Frigidaire Kitchen Ranges
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
254 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
