Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu5315 06
Purchased a used bosch shu5315 06, which we were assured worked fine. ha! Have replaced the control board in it and dishwasher now will start wash cycle, fill with water, drain water, then fill with it again. At this point it stops working while the timer continues to count down. We have to use the clear function to get it to drain the water out. Any ideas what we should check next? My husband is fairly handy but we do not really know exactly how the dishwasher is supposed to work through it's cycles when it's running a normal cycle. Thanks for any help you can give us!
  • ricsan Jun 20, 2008
    Thanks for the help. My husband and a friend ended up taking part of the dishwasher apart and found that the motor was "frozen". Once they fixed that it seems to run fine. Thanks again!
    President:
  • 1,462 Answers
It sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Posted on Jun 20, 2008
How do I run a diagnostic test on the Bosch shu5315uc/u12? The cycle time of my dishwasher is at least 4-5 hours.
Long running time on a Bosch dishwasher is almost always a blown solder joint at the heater relay on the control board. You can resolder the joint, replace the relay or replace the control. Control board part number is 00266746.
Jan 13, 2015 | Bosch Dishwashers
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Bosch Dishwasher tells me a cycle will take 75mins when it used to take 35mins. I have replaced a relay on the CPU which has fixed the problem of it not heating, but not sure why timer is all wrong. The...
BOSCH IS HAVING A PROBLEM RIGHT NOW WITH SEVERAL OF THERE CONTROL BOARDS...as a matter of fact just out today on a bosch shu33 model dishwasher and control was bad and was told by a local supplier there is a recall on these control boards.... based on you explaination it sounds like the control is bad and will need replaced... good luck to you..
Jan 06, 2011 | Bosch Dishwashers
Hi, My dishwasher won't drain after a full cycle. Any ideas? Thank you! It's a Bosch
break out the honey do list . ah ha ha ha ha ha
the food debris from washing has your drain line stopped up. start with the p-trap under the sink, and flush out the gunk . then if needed maybe a backflush with the waterhose thru the drain tube that comes from the washer to loosen some food particles. use low pressure so you dont have to mop up too. thats usually the problem
Jul 31, 2010 | Bosch Dishwashers
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Jun 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher cycle doesn't end
Try this link, http://www.applianceaid.com/boschDW.html for procedures for running self-tests on various Bosch models using the front door switches. Find your model and read and follow the procedure.
This remaining at '1' problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. See pic here of open solder joint http://www.flickr.com/photos/zenzoidman/145089572/ In most cases, the heating element has not been at fault.
I got mine going again by resoldering the joint and saved ~$300 in parts & labour. If this is beyond your skill set, then replace the control board assembly, 266746, which is used on multiple Bosch models. See this page for more information if you want to try to DIY. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
If this is still beyond your skill set, then call a tech & supply the Bosch model, serial number, and the results of the self-tests.
Jul 08, 2008 | Dishwashers
Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
May 27, 2008 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Sep 04, 2007 | Bosch SHU3306UC Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
332 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
