Question about Hitachi 55HDS69 55 in. Plasma Television
Crackling Sound I have Hitachi 55HDS99.  Last night, all of the sudden, I started getting a crackling sound through the speakers.  The crackling sound now won't go away. What's the problem and how do I fix it? Thanks for your help.
  • Crypto888 Jun 11, 2008
    About two months ago, the sound on the Hitachi 55HDS69 55 in. Plasma Television stopped working. All that comes out of the TV speakers is a crackling sound. I've had to patch it through a sound system just to have sound while watching TV. Is there a solution for this? Did someone accidently hit a button on the remote that would kill the sound and leave the crackling?
    Problem Solver:
  • 53 Answers
Hello there
The issue that you are descibing sound it a bad small signal board which needs to be taken to thr repair shop.
Posted on Aug 09, 2008
Protron tv crackling sound
The speakers that are inside your tv are damaged and needs to be replaced, after you replace your speakers, the Sound will return at the correct factory settings from which you received your tv..
Feb 10, 2013 | Protron PLTV-37 37 in. LCD Television
Picture quality is dim. There's also a continuous crackling sound emanating from the rear area, I believe in the area where the lamp goes. Is this merely a lamp problem?
check the lamp ballast board which may the cause of dim and crackling sound. check for bad high voltage transformer and dry joints connector at the ballast board.
Sep 07, 2012 | Hitachi 50VS810 50" Rear Projection HDTV
Amp crackling noise
Sounds like you could have a blown amp/speaker or you've got a short in your speaker lead. Typically, when there's not enough resistance on a wire is when you start getting the crackling noises.
Aug 06, 2012 | Televison & Video
Last night, 4-24-20ll (in the middle of the night) I was watching a video and suddenly there was a crackling noise like static. Then the sound disappeared completely and never came back.
I think a harsh sound damaged the speaker. This is usually caused by software signed to enhance audio performance, such as VLC (which has high sound volume), Breakaway (a so sound-enhancing software, etc. First of all, try uninstalling such programs, or if you have not installed such programs, try restarting your computer several times. Secondly, test other speakers (external) with your computer to see if the problem is from your previous speakers. Hope this helped.
Apr 25, 2011 | Computers & Internet
I have a pair of Peavey Hysis 2 speakers. At a gig on Saturday night one of the started crackling when loud vocals went through. I set them up in the garage next day and the cab that had been crackling...
You have likely almost but not totally fried a voice coil in your speaker. Most speakers get cooked from underpowering, not from being overdriven. What are the speakers rated for and what are you driving them with?
Nov 17, 2017 | Peavey CH1 Speaker
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Crackling sound
That sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
May 01, 2009 | Bose Companion 3 Computer Speakers
TV is crackling
From the speakers or from the inside of the unit. On all modes, eg. normal tv + digibox/scart input???
Apr 05, 2008 | Televison & Video
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
Hitachi 55HDS69 55 in. Plasma Television Logo
242 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
