Question about LG Washing Machines
Lg model wd8074fhb error code de what does it mean
  • 868 Answers
You have a blocked pump,Remove the lower front panel ,remove the pump hoses and clean out pump/hoses.Please rate this , Thanx.
Posted on Jun 05, 2008
My LG Washer/Dryer shows error code dE
De error mean door is open. Check the door switch. You found in the link below how to reset the maschine http://www.lg.com/us/support/product-help/CT10000010-1400508168566-de
Apr 09, 2018 | LG Washing Machines
Why does my LG washing machine model WD(M) 16115FD show error code dE?
It appears to be a problem with the door? You can go to the following link and try their troubleshooting, hope it helps. http://www.ehow.com/how_7850983_troubleshoot-de-code-lg-washer.html How to Troubleshoot DE Code for an LG Washer eHow
Aug 10, 2014 | LG WD-16115FD Front Load Washer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
May 30, 2010 | LG WD-16115FD Front Load Washer
Lg wd8074fhb will not rotate drum on was or rinse
LE=Load Error CE=Cycle Error
Unplug at socket for two hours will reset the Error Sensors. The sensors are there to prevent overheating of the motor and the possible risk of a fire.
Load Error is linked with too much weight in the drum. Cycle Error is limked with an uneven load.
If it happens again, unplug for two hours to reset the Error Sensors.
Hope this helps.
Nov 16, 2009 | LG Washing Machines
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
My LG WD8074FHB is saying SE what does that mean
Call 1-877-714-7486 for free LG help.
Have Model and S/N
Reset machine and Check again.
Feb 22, 2009 | LG WM1814CW Front Load Washer
De is displayed when i turn machine on
Error code DE means door error problem.  Could be that the door switch doesn't sense the locking mechanism is working properly and may need to be replaced.  This will require a service call from a qualified LG tech to diagnose the problem.
Jan 04, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
230 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
