Question about Seagate Barracuda 7200.7 Plus (ST3120026A) 120 GB Hard Drive
Seagate Barracuda 7200.7 Plus 120 GB... Failed or broken
My computer won't start window. Window logo was open thats all. I installed and ran utility disc that came with the hard drive and said " hard drive failed, contact computer dealer or vendor of the drive for return. I checked seagate website but didn't find anything on how to return the hard drive for fix. When I bought this it was advertised that has five years warranty. Any body please tell me how to fix this problem or how can I return the hard drive to seagate? Thanks in advance.....
    Top Expert:
  • Seagate Master
  • 24,742 Answers
The serial number will authenticate a warranty repair. Enter the serial number in the web site where prompted and it will give the date of manufacture and allow you to print a returns label plus there will be some software to download, that will prove a fault or not.
Posted on May 29, 2017
  • 244 Answers
SOURCE: hard disk I/O error cannot formate harddisk shows no fixed disks how to solve
Please try to check with your cmos system if it was detected, if not means your harddrive was absolutely damage.
Please rate me solved!
Best regards,
Posted on Nov 17, 2007
  • 449 Answers
SOURCE: My seagate barracuda 7200 b will not boot up. It has been operating fine for the last 8 months
i suggested you use NORTON DISK DIAGNOSTICS to repair the MBR(master boot record)the master boot record is bad and you can use winXP bootable nto repair the drive by pressing R after booting is completed.but you need to be able to use DOS prompt before you can do this
Posted on Feb 06, 2008
  • 102 Answers
SOURCE: computer does not recognize mY SEAGATE BARRACUDA 7200. 11 500 GB
Try using your SEAGATE Hard Disk on another PC , if it works then you have one of these problems,
1. Your USB Port in your PC (Or Laptop) is broken and you have to get another one*
2. You have a software problem (Try reinstalling your OS or scan for viruses).
3. The USB Cable has a problem (get a new one).
(*) some technician can replace your USB port or fix it, or you can buy a "USB Hub"
Posted on Jan 25, 2009
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
SOURCE: firmware update for Seagate Barracuda 7200 10 80
Dear FixYa team,
Thx for your kind offering to me. I already call my friend to help me here. And he seems already found the solution. The problem was comes from USB cable malfuction, and I think it somehow affect the firmware detection. Gladly he can back up it again with another harddisk, just try to baiting it to make the firmware read. Now I'm still waiting for data recovery only. I'm so sorry that I can't use ur helps now, coz I needed it in hurry. Thx
Posted on Jun 27, 2009
Can I install Seagate barracuda 160 gb 7200 sata hd to replace hd in OptiPlex 360?
Yes you can
Assuming you have backed up all your data that is important to you (pictures , files, documents etc)
WARNING you will have to reinstall windows on to your computer after installing new hard drive!! make sure you have windows disks
here is the link on how you replace it. Its on page 70
hope that helps
Oct 18, 2013 | Dell Computers & Internet
My new Seagate Barracuda 7200 does not
Hi Simlei.
If its a modern, fairly new drive, it should have built-in firmware, without a need for extra drivers.
If you OS is old the OS itself may not be recognizing the drive's 'language', especially if the bus-width differs, ie 16/32/64bit.
As 1 TB is quite recent on SSD's, I guess its new.
My 1 TB Toshiba just plugs into USB and Win Explorer detects it as a storage drive.
Regards, Clive.
May 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My seagate barracuda 7200 80 gb having s/n: 9qz0c2zz is not recognize by my computer im using windows xp operating system
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard disk failure... unable to start
You need to get a new Hard disk. There is no way to get info off the Hard disk that won't turn in because theres probley a short a an element that failed and burned out. Hope this helped. =)
Feb 25, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
I've just installed the same type of hard drive in my PC running win XP and have no problems.. do u know that you need to format the disk before it will show up with the other accessible drives?
what to do is - click start, right click on my computer and go to manage.. then double click on storage, disk management local.. and it should show up here, once you format it your all set..
No need for drivers, windows has them already, it's all generic one's the windows is familiar with..
Hope this helps!
Dec 16, 2007 | Seagate Barracuda 7200.9 ST3400833AS 400GB...
Computer won't recognize my HDD in my external enclosure...
Hi, Initially, allow Windows to install automatically drivers or needed configuration, then perhaps you need to reboot. Thereafter check if it can be seen in My Computer, otherwise, pls post back for any messages or errors. Good luck and kind regards.
Sep 03, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate Barracuda 7200.7 Plus (ST3120026A) 120 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
