Question about Akai PT4298HD Rear Projection Television
Convergence The convergence is off on my akai pt4299hd and i don't know how to get into the service menu to fix it nor what buttons to push when i get there
  • Akai Master
  • 8,617 Answers
Youre convergence ICs need to be replaced there are two of them STK392-040 you can get new replacement ICs and free instructions with pictures at the following link.
http://servicemanuals.vstore.ca/
Posted on Jun 05, 2008
Akai rear projection tv...picture is not deformed....however there are images (Ghost image) in separated colors...like 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 24, 2010 | Akai PT5598HD 55" Rear Projection...
Hello, my tv looks 3d
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 12, 2010 | Akai PTH5498 54" Rear Projection...
Need convergence instructions foe akai pt5299hd
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Dec 02, 2009 | Akai PT5598HD 55" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Akai PT4799HD - Bluish and Distorted Screen
  • Screen looks 3D
Mar 01, 2009 | Akai PT4799HD Rear Projection Television
Akai/Samsung PT4299HD Convergence Problem
Ck 3 low ohm resistors 2.7 ohms they will be on same board as ICs.
Feb 13, 2009 | Akai PT4298HD Rear Projection Television
Try resoldering the pins on the ICs first. If that fails to resolve the problem, change the IC responsible for RED. You should be able to determine that from the service manual. In that area you should also see either fuses or low valued resistors that feed the STKs. Check those as well.
Let me know if you need further info.
Dan
Feb 13, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Akai pt4299hd
replace your STKs big black Ics STK394-250 there is 2 of them thses are your convergence ics.Also ck resistors and pico fuses.
Jul 22, 2008 | Akai PT4799HD Rear Projection Television
Akai PT 4299HD picture shift
Sounds like you got it ! Note for the future....if you change
convergence amp IC's...be sure to use top quality name brand
only....no generics ! I use Panasonic with no re-calls.......T.
Feb 18, 2008 | Akai PT4298HD Rear Projection Television
Need akai pt4799hd setup code
Do NOT attempt to enter the service mode to align convergence if you cannot align the convergence with the user's menu. If the convergence cannot be corrected with the user's menu, it means that one of your convergence IC's has burned out and possibly burned out the fuse next to it. If you change any settings without first replacing the bad parts, you will only make things much worse. I believe that set is actually a Samsung, and has the 2 convergence IC's on their own board mounted above the small signal board. If you do not know how to identify and replace shorted convergence IC's, allow a qualified tech to handle it for you.
Sep 03, 2007 | Akai PT4799HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
198 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
