Question about Panasonic PT-40LC12 40" Rear Projection HDTV
No power try to turn my tv on it will not come on.
  • musicluv7852 Jul 09, 2008
    whenever i turn on my tv it will stay on for about 5 min and then it turns off
  • 19 Answers
Any warning lights showing a possible overheating situation?
Posted on Jul 09, 2008
TV will not power on. Red light flickers sometimes when I try to turn it on.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
May 1, 2014 - Uploaded by
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and causes of ...
SONY ' eSupport - The TV will not turn on or does not have ...
Aug 15, 2015 - The TV may not turn on if there is a power issue. Often power issues are caused by a drop in voltage in an electrical power. The power outage ...
TV has power but will not turn on - Page 2 - Community ...
Feb 1, 2015 - Our tv has power to it but will not turn on. The red light in the corner is lit but when we try using the remote or the power switch on the unit.
32" LCD Flat screen TV, no power, can someone help save it ... > Forums > Miscellaneous > Off-topic Chatter
Feb 2, 2012 - 20 posts - ‎10 authors
The tv will not power on manually or with the remote, there's no clicking noise, no LED light on the front, no signs of life. There is no obvious ...
TV Will Not Power On
Jan 26, 2016 | Televison & Video
What does a orange not blinking indcator light mean?
For your TV the power light will be red when the TV is turned off using the power button on the top of the TV. Press the power button on top of the TV if that does not work then try turning the power off at the power switch on the bottom of the TV then turn it back on after a minute ior so and see if you can turn it on using the power button.
Aug 05, 2014 | Protron PLTV-37 37 in. LCD Television
Power on problem
1) test the outlet wall plug a desk lamp for to see if word, if does goto
1a) test the power cord
2) test the main switch for open or defective
3)go to the power supply see if the blown fuse replace or c.breaker reset.
4) if the problem persist, see for short in diode, transformer, filter, coil,rectifier.see the block diagram
God bless you
Aug 01, 2012 | Mitsubishi WS-65819 TV
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
first you need to do some troubleshooting, if you try turn it on with the remote, now try pressing the power button on the tv, check your power cord. Also try to do a power reset by disconnecting the cable from the power outlet, then press and hold down the power button on the tv not the remote for 30 seconds. release it plug it in to the power outlet and try to turn it on. If the issue continues, then your power supply board is damaged.
Aug 26, 2010 | Vizio VP322 32 in. Plasma TV
Tv will not turn on
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like, to buy a whole rerfurbish power supply board for the replacement.
May 23, 2010 | Akai LCT3701AD 37 in. LCD Television
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
TV wont turn on with power button or remote
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
Jul 04, 2009 | ViewSonic N3735W 37 in. LCD TV
No picture
when you say has got power, but wont turn on, i pressume your TV is on standby mode. have you tried your remote control to turn it on? or try the TV panels? if you have tried those but still wont turn on then you have trouble with the mains power supply of the TV. have it checked by a techincal person.
Apr 07, 2008 | LG 42PC5D Television
Toshiba 50A60
take your tv to a tech it needs repair.if you are not a tech you wont be able to do it your self.the tv is having problem in the power supply and other related circuit.good luck.
Apr 03, 2007 | Toshiba 50A60 50" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
