My dell 1600n will receive and send faxes, but I am unable to print anything from anywhere. I did the trouble shoot on the system, and no help. The computer is hooked up to a routerMy dell 1600n will receive and send faxes, but I am unable to print anything from anywhere. I did the trouble shoot on the system, and no help. The computer is hooked up to a router
Same issues. Some print some do not. Also when a fax will not work , it shows up as recieved, but no caller ID.Same issues. Some print some do not. Also when a fax will not work , it shows up as recieved, but no caller ID.
AnonymousJan 05, 2009
my dell laser mfp 1600n will not fax are receive fax.my dell laser mfp 1600n will not fax are receive fax.
Will it print reports from the menu? (in other words, print from an internal source) and / or will it print a page is you hit "copy"?Will it print reports from the menu? (in other words, print from an internal source) and / or will it print a page is you hit "copy"?
You can't post conmments that contain an email address.
Dear As the model is not mentioned its difficult to right solution. But in general when a document sent from memory some times this happen. This is frequent if memory recieved is more and not printed. Its cleared on printing all memory recieved or memory cleared(all received fax will deleted). Also sending fax manually may be done.I.e.Dial the fax no.get the fax tone load the document press start or send. Also in setting the scanning resolution may be minimised up to150/200dpi for less memory. Thanks.
You cannot print out a sent fax, but you can print a report that give you a status of all faxes sent and received.
Press Setup, press 1
Press > (the right arrow) until you get to "Fax Log"
Press OK to select the report.
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
