Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi modle# WD52525 serial# 122342
Tv was working fine this morning, came home from work turned it on it had a blue screen with vertical green lines all through the center. I cleaned out my little dust collector and replaced. I tryed to reset it, i also cleaned out the area where the lamp is. We had our bulb replaced only about and not even a year ago. What do you think the problum might be?
  • Mitsubishi Master
  • 8,617 Answers
Bad capacitors on the FMT there are 3 1000uf 16v capacitors that will cause that symptom. Your onscreen menu is unaffected right? If you need more info or a link to the service manual for thet model you can get the service manual at this link.
http://servicemanuals.vstore.ca/
Posted on Jun 05, 2008
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
I have an older modle Mitsubitshi big screen tv and the blue color is not lining up. What could the problem be?
how bad is it? if it is not to bad then you should be able to run an auto converge from the customers menu if it is really bad then the convergance amp have fail and need to be rplace about a 200 dollar job
Nov 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture
If i am to understand this correctly, this is a rear projection television. Inside there may be 1 - 3 " color " control boards that control the picture before going on to the projector. an accumulation of dust / dirt / debris has adverse affects on electronic componants, make sure they are dust free (compressed air cleans them off quite well. If using a home compressor, make sure there is a vapor filter to remove water from the airlines.)
If they are clean, and as you said you recently had the television serviced to replace the projection lamp, take the television back to the repair shop to have them determine the problem.
If you yourself replaced the projection lamp, be sure to check all connections are properly seated if you had to disconnect something, make sure they are in the proper places, and any connections are securely connected.
If all else fails, have a local electronics / television repair person check the unit for faulty componants.
May 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
Blue,red,green lines on top of screen for couple months. Now tv wont work.
The foldover is because of a bad capacitor in the vertical circuit. Given the "new" sympotom of a dead set, I would suspect that the vertical IC has failed. This should be a relatively simple repair for a TV shop. If you wish to attempt a repair of this yourself, update this and confirm your model number and I'll post more details and instructions.
Dan
Nov 10, 2008 | Philips 32PT5441/37 32" TV
I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after...
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Oct 20, 2008 | Televison & Video
Mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to www.tv-techs.com
Oct 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD52525 had a blue screen when turned off
Perfect Blue screen usually means video problems. Leave unplugged and try again to make sure.
Aug 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
