Question about Sansui Audio Players & Recorders
I need a replacement volume control for a Sansui-AU-717.
  • 1,512 Answers
Hi p00pmeister
This great old amp uses an Alps brand attenuator. This could be a little hard to find an exact fit replacemernt. Have you tried to clean the control. The can generally be restored by flooding the internals with CRC 2-26. If you have intermittent channels, check also the amp/preamp switch to the rear of the amp also.
Check out this Has some instruction on dealing with the disassembly of the attenuator
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 05, 2008
Remote for AU X911DG SANSUI
U can try getting from manufacturer but they charge a fortune for those things. Best bet is to look for it on ebay or Amazon.
Aug 28, 2015 | Televison & Video
Sansui 7070 receiver Hum
Your filter capacitors in the power supply section are to blame and they need to be replaced.
Mar 30, 2014 | Sansui 221 Amplifier / Reciever
My sansui tu 217 makes a popping noise and looses all volume when i turn it above 1
Volume controls these days pass signals to an IC that controls most functions such as volume and tone. Following the wiring from the volume control should take you to the this IC which will need to be replaced.
Jun 19, 2013 | Audio Players & Recorders
Off of the top of your head could you tell me what my problem with my sansui AU-717 amps problem could possibly be? When I am playing a cd if the volume is even barely loud the sound will go out then I...
It sounds like one of the following:
> You have an impedance miss-match between your speakers and the amp (speakers have am Ohm rating lower than the amp can handle),
> You have the switch set to both A&B speakers turned on, but have speakers connected to either the A or B set, but not both, or
> You have both A & B (4 speakers) connected, and one or both have an Ohm rating lower than 8 (if two sets are connected, they must be 8 or higher).
My best guess off the top of my head.
Apr 07, 2011 | Sansui Audio Players & Recorders
Hi I have a Sansui Amplifier model AU-519 and the volume of this goes of quite often...only resumes when the volume knob is rotated anticlockwise and clockwise several times....is there a fix / solution to...
Sounds like it could be one of two things, either a bad soldering joint, weakend with time! Or dirt in the track of the control. This can be cleaned with Servisol Switch Cleaner (such as Video 40).
Aug 27, 2010 | Audio Players & Recorders
I have a Sansui AU-717 amplifier with a bad volume control. How do I find either a replacement or someone who can repair it?
A replacement control will be difficult to locate as it is long out of standard service time. That being said, it is also rather rare for a control to fail completely. Can you please indicate why you feel the volume control is defective? Perhaps there is another problem that will be easier to repair.
Thanks,
Dan
Jun 27, 2010 | Audio Players & Recorders
Sansui AU-7500 volume control problem - need replacement
Hi...
Is that the fancy pot with more than 6 leads..kinda square looking?
This place has some.
http://angela.com/
Rate my help if this helps...Thanks
Mar 11, 2010 | Audio Players & Recorders
I have a sansui au-717 ampand the left speaker side dosen't work for either A or B speakers. already swapped speakers so I know it's not a speaker problem..........
the amp will most likely need to be replaced but the pre amp will need to be checked first
can you perform these tests ?
electech
Nov 26, 2008 | Audio Players & Recorders
I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
I have a Sansui AU-717 Integrated Amplifier that needs some work done on it. Is there a Sansui service center in Washington State that can work on this?
This company is not like they used to be. You can try the links below to see if you can find authorized service for your set.
Sansui:
http://www.sansui-india.com/
http://www.classicsansui.net/
Historic information about Sansui:
http://en.wikipedia.org/wiki/Sansui
I would personaly suggest to find a service center or a very good local tech who can do audio amplifier and reciever service.
Jerry G.
Apr 13, 2008 | Audio Players & Recorders
88 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
