Question about Philips 5-Device Universal Learning Remote Control
I need cobes for my Magnavor remote and away to lock it in
Hello therer I need codes for my remote my kids get a hold of it and I lose the code all the time is there a way to lock it in
I no loger have the book for it so I need the codes for a SHARP TV
  • 4 Answers
Using the Phillips Magnavox 5-device Learning Universal remote (Consolidator model MRU3500) requires 4 digits to program this particular remote. Not sure if this is the remote that you have but the codes are:
SHARP brand including LCD, Plasma & Panel televisions - 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
Posted on Oct 14, 2008
  • 156 Answers
Follow this:
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
CODE FOR SHARP TV :( 002 013 014 111 502 712 812 813 913 918)
Posted on Jun 05, 2008
I need the set up code for a oneforall remote for a rca tv urc6012boo
Hello
There is no codes found in its user manual. Only code search process is given. We ahve to search and find the code of our device.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then
release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its
library to the selected device, starting with the most popular code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1
through 5, but substitute the appropriate device key for the
device you are searching for.
Jun 27, 2011 | Televison & Video
Need to set my one for all remote to a Toshiba TV?
Try the following codes: Toshiba 0060, 0154, 0156, 1265 . Turn on the TV manually and then press the TV button on the remote. Press and hold Set until the LED blinks twice; then release the button. Enter the four digit code. The LED should blink twice again. Test if the TV turns off by pressing Power once. If it does, check if the other features of the remote control the TV. If it doesn't, try a different code. You can also manually search for a code by pressing 9-9-1 after holding and releasing Set. Then alternate between pressing Power and TV (for a TV code). Lock in the code when the TV turns off by pressing Set. Check if the remote works for other features.
You can get the manual and codes for the One For All remotes here: http://www.oneforall.com/support/manual .
If your remote is older than your TV, you may need a new remote. Universal remotes are usually limited to codes for devices released 6 months or more before the remote was programmed.
I hope this helps.
Mar 15, 2011 | One For All URC4220 Remote Control
I don't know the code to my Panasonic VCR
Hello;
According to the manual located at
http://www.hifi-remote.com/manuals/manual.shtml?URC-3300 , the codes for a Panasonic VCR are: 0035, 0162, 0225, 0454, 0616, 1062, 1162, 1262.
If none of these codes work, you can find the code for your VCR by doing the following:
1. On the remote control, press VCR once.
2. Press and hold SET until the LED blinks twice, then release SET.
4. Aim the remote control at the the VCR and slowly alternate between pressing POWER and VCR. Stop when the VCR turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope this gives you the information you need.
Mar 14, 2011 | One For All URC-3300 Remote Control
Hello i have a one for all universal remote and can not find codes anywhere
Without knowing the specific model number for your remote, try the following procedure. It's the one common to many of the One For All Universal Remote models which enables a code search from a library contained within the remote.
SEARCHING FOR YOUR TV CODE
2. Press and hold SETUP until the LED blinks twice, then release SETUP.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off. This means the remote has found the code for your TV.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first. You may have to repeat the procedure in Step 4 several times before your remote finds the code for your TV.
5. To lock in the code, press and hold SETUP until the LED blinks twice, then release SETUP.
6. To search for the codes of your other devices, repeat steps 1 through 5, but substitute the appropriate device key for the device for which you are searching.
Hope this helps.
Feb 24, 2011 | Televison & Video
Kids locked up the TV, need code to unlock it.
Try this: press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
Apr 21, 2009 | Jensen JER-323 Remote Control
I need the code for a Samsung DVD-V9650 dvd player
There are two possible codes for this product.
1. Hold the remote away from the DirecTV box.
2. Slide the button on the top to AV 1 or AV 2.
3. Point away from DTV box.
4. Manually turn the DTV box off.
5. Hold down the select and mute buttons at the same time until the light blinks rapidly for a second.
6. Press in one of the following codes and press the power button. 7. If the DTV box turns off, press the select button. If not, repeat steps 5-7
Possible codes: 20573 or 20820
Dec 09, 2007 | Directv RC23 Remote Control
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
Innovage Jumbo Silver Remote
Hello , I need the code for olevia 32" lcd tv and viewsat sat reciver , thank you , ray
Aug 29, 2007 | Televison & Video
Philips 5-Device Universal Learning Remote Control Logo
167 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
