Question about Freezers
Problem I have a kenmore comercial upright freezer. It stopped working yesterday. It makes niose, and the light is on, but the food is defrosted. I need to know if there is a defrost switch or a reset switch, and where they are.
    Scholar:
  • 149 Answers
It sounds like your compressor isn't running. i'd check if it is. go the that area and put your hand on the compressor (just tap with finger) if it's hot, suspect that your compressor ain't running.
Posted on Jun 08, 2008
I have a Kenmore upright freezer model# 253.9260210. We noticed that our food was starting to thaw. I opened up the coil area and noticed a small piece of ice on the coils. I melted the ice and turned...
Feel top of the compressor and tell me how hot after it has been running awhile. I need also that you advance the defrost timer=>. 216517400 Defrost Timer
clockwise slowly untill the compressor stops or starts. I need to make sure the timer is not stuck into defrost. I want you to leave the compressor off for up to 35 minutes. If the freezer compressor doesn't restart bt then simply again turn the timer clockwise slowly until it does and then stop turning. The defrost timer is location 23 in this photo HERE If you need to turn the defrost timer like this to restart the compressor then replace the defrost timer and this will resolve the freezing problem. If not we move to the defrost heater location 14 in the sme photo=> 216254600 Defrost Heater
I am going to stop here until I hear from you, Thanks Sea Breeze
Dec 08, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Groaning Kenmore 13.5 cu. ft. Upright Freezer
This sounds like you either have a bad fan motor or if you have ice built up on the inside back panel. It could be that the fan blades are hitting ice built up around it. If so, you will have a defrost problem that will need to be addressed to fix the unit. But to repair it so it will stop making the noise, you can defrost the ice (if present) with a hair blow dryer. This will keep the ice away for a few days. Good luck.
If there is a defrost problem, the heater (located around the coil) is most likely the problem.
Nov 17, 2009 | Kenmore Freezers
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Any possibility you can help troubleshoot a larger upright freezer? Our freezer is 3 years old. It sounds like it is working -- I can feel cold air and hear it humming, but as of yesterday it stopped...
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Jul 25, 2009 | Haier 3.6 cu. ft. / 102 liter Chest...
Kenmore manual upright freezer
we got alot of ice chest and cleaned out the ice. this fixed the problem so far. we dint lose any food thank goodness.
Jul 07, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
117 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
