Question about Refrigerators
Whirlpool refrigerator gets too cold
My Whirlpool refrigerator has just started freezing milk. This is entirely a fridge only, no freezer in it. I replaced the thermostat. Still have the problem. Just now checked that the circulating fan is working. It is. What should I check next? The model number is EL7ATRRMS07.
  • 1 more comment
  • blambmn Jun 06, 2008
    We used to have the thermostat set to 4.5. Now, if I set it just under 1, the fridge warms to about 48 degrees. If I set it just over 1 (1.1), the fridge cools to 25 degrees.
  • blambmn Jun 09, 2008
    Its everywhere. I've placed a thermostat on several shelves, and on the front and back of those shelves. I was hoping the fan was out and not circulating, but its running fine. And all the vent holes are open. No food packed in front of them, and no clogged holes. When the fan is running I can feel a lot of air circulating.
  • blambmn Jun 11, 2008
    Still no help with my problem. Can someone else pitch in?
    President:
  • 2,712 Answers
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Jun 11, 2008
      Problem Solver:
    • 8 Answers
    I had the same problem... Mine was from the coil's being block with dust bunnies... Try cleaning the coils and see if that helps you...
    Posted on Mar 25, 2010
    • scotty560 Aug 09, 2014
      The other problem was the Thermostat. I replaced the Thermostat and it's been working great for 4 years now.
      Master:
    • 555 Answers
    Is the temperature problem localized to a specific area of the fridge, or everywhere. Generally the rear of the fridge gets the coldest.
    Posted on Jun 06, 2008
      Master:
    • 638 Answers
    This is the link from where u can solve your problem and get a perfect solution.
    http://www.applianceaid.com/refrigerator.html
    if this solution helps please rate it as "fixya" and encourage us to solve more problems. thanks for using fixya.wish u success.
    Can you tell me why please?
    All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
    Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
    Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
    My fridge freezes milk and everything in it
    If the fridge is freezing everything, try this before thinking it's the thermostat first turn down the temp gauge in the freezer, not fridge to about medium, still a bit to cold turn down a little more. It save me heaps
    Aug 13, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
    Whirlpool fridge model GD5YHAXTL 01 gets too cold. Milk is freezing. So far I have cleaned it out and it is currently unplugged.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    heatman101
    Sep 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Fridge and freezer not staying cold - Got home last night and my whirlpool (frost free) fridge/freezer was switched on (power running to it - light etc working) but was not chilling properly. Everything in...
    This can happen if the fan motor in the freezer compartment is bad. Causes the freezer section to freeze up and you will not get air circulating, so no cooling. Check the fanmotor
    Nov 06, 2009 | Cars & Trucks
    Whirlpool intgrated fridge/freezer is not keeping
    7 is coldest. but how cold is the freezer? all cold is made in freezer. ma be developing a frose problem
    Jul 06, 2009 | Whirlpool ED2GHEXN Side by Side...
    Freezer not freezing food and fridge not staying cold enough
    Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
    Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
    Freezer suddenly stopped freezing and fride is not getting cold
    Hi, I would try putting your refrigerator and freezer control switches on medium. Good Luck,I hope this helps you out.
    Nov 07, 2008 | Whirlpool Refrigerators
    Fridge not cold
    my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
    Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
    Freezing problem
    I think you mean that milk freezes, etc.
    Probably bad thermocouple. In the refrigerators I'm familiar with, there is a thermocouple thermostat in the freezer. There is no measuring of refrigerator temperature; it just gets a portion of the cold freezer air.
    If the thermostat is bad, then ice cream should be rock hard too, for it never quits cooling except on defrost cycle, three times per day.
    Jun 16, 2008 | Candy CPCA270FFK Bottom Freezer...
    Refrigerators Logo
    5,985 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
