Question about Refrigerators
Slow water, hollow ice in refrigerator
Kenmore Model # 51572200 - Water comes out REALLY slow and the ice is hollow...Put in a new filter so that is not the problem.
  • 114 Answers
Sounds like your water inlet valve is malfunctioning. This is a dual solenoid valve located in the back, behind the cardboard cover.
Posted on Jun 05, 2008
Why is the water on my kenmore refrigerator coming out so slow?
I do not know the unit but it sounds like the water filter has plugged. Just replace the filter and the problem will go away. The ice maker can fill very slowly and you would not notice it.
Aug 24, 2014 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
My frigidaire gallery french door refrigerator is making ice very slowly. the water is coming out fine. It is only 4 weeks old. i got solutions from frigidaire from the valve to the water filter. Any...
The theory to making ice is temperature, water, and ice mold to function. What are the temperatures inside the freezer currently. It must be below 15 degrees to function and prefer the freezer to be at 0 degrees to product effectively. Are you ice cubes solid or hollow? If hollow you can jam the ice inside the ice maker causing slow production. Rare to have a water valve problem this young be is possible. I would look at temperatures first than cycle time to determine the next step. In a perfect world, your unit should drop ice every hour to and hour and a half.
Good Luck
Jul 23, 2011 | Refrigerators
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Why would the water start coming out very slow?
If you are referring to water coming out the fountain it could be a leak in the system somewhere allowing air into the lines that run the water, if you are referring to water coming out of the ice maker itself you need a new ice maker the lining is bad
Jul 14, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
I have a Kenmore side by side refrigerator/freezer. I am getting really slow flow from water dispensor (outside freezer side door). It takes 20 seconds to fill up a glass of water.
check to see if your ice cubes are well formed or hollow / if hollow replace your filter 1st and if no good replace your water line / if cubes are large and well formed the replace your water valve to fix your water problem.
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Jenn air Mdl#jcd2389ges Very slow water dispenser
You will probably find that if you have a water filter in your model refrigerator that is is clogged. Replace the filter and voila, good flow again. You probably also have small or hollow or chip ice cubes as well, if your filter is clogged.
To save the cost of the filter you would need to check to make sure you are getting strong water flow to the solenoid valve located in the bottom rear of your refrigerator.
I hope I helped, supertechks
Mar 27, 2008 | Jenn-Air JCD2389G Side by Side...
ICE MAKER and Water Dispenser
very likely a partially clogged filter, but not sure why no light.
Jun 13, 2007 | Amana ARS2661B Side by Side Refrigerator
Hollow Ice- Slow Ice!!
Hollow ice is a dead give away that there is not enough water filling the trays. Check that the line isn't pinched from pushing the unit back in place, etc. Also check any filters or filter screens in the water line to the ice maker.
Jan 13, 2007 | Kenmore 55692 / 55694 Side by Side...
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
