Lexmark 3400 printer display says cover is open. Cover is not open. apparently it is mis reading status. will not print or turn off. Its stuck. What do I do? D.S.T
    Brigadier General:
  • 3,614 Answers
Did you experienced a paper jam before, kindly check the printer cover switch if it not defected..
Posted on Jun 05, 2008
    Genius:
  • 1,142 Answers
Do a hard shut down..unplug power cord...that would make it go off. them leave it off for 2-3 minutes..then turn it back on and let me know the status
  • Maanita Chadha
    Maanita Chadha Jun 05, 2008
    Possible cause of the error
    This can happen if the lever on the cover open sensor is knocked off the switch assembly.
    What to do
    Try to determine if there is a hardware fault. To do this:
      1. Disconnect the power cable and the USB cable.
      2. Remove the cartridges from the printer.
      3. Check that the power cable is plugged directly into a wall socket.
      4. Reconnect the power cable.
      5. If the error persists, please contact Lexmark Technical Support for further instructions.
    Contacting Lexmark
    Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for service, you will need to know your printer model type and serial number.
    Please call from near the printer in case the technician asks you to perform a task involving the printer.
  • Maanita Chadha
    Get immediate assistance with a technical question 24 hours a day.
    Online Technical Support
    How to Contact Us Regarding Your Product
    http://support.lexmark.com/cgi-perl/emai...*framed=&re_from=jaguar_link" target="_blank" rel="nofollow" >e-Mail a Support Representative
    Call us at 1-800-332-4120
    Monday through Friday
    8:00AM - 11:00PM ET
    Saturday
    12:00PM - 6:00PM ET
Lexmark x5250 flashing green power light
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Jan 25, 2012 | Lexmark Office Equipment & Supplies
Paper jam dx7400
Here's how to clear the paper jam,
  • Open the paper tray and remove all the loaded papers.
  • Open the printer cover and check through for any stuck papers and remove them manually.
  • Close the cover and turn the printer off.Wait a few minutes then turn it on.
Now try to run a status print by:
  • Turning on the printer.
  • Load a paper
  • Press the right arrow > three times.
  • A status sheet is printed.
Hope this helps.Thanks!
Nov 02, 2011 | Office Equipment & Supplies
Is only blinking and not printing when i try to print the usb conect successfuly to the compter but the printer is not printing the light is only blinking
The blinking light could indicate either a paper jam, communication problem between one of your cartridges and the printer or a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
  5. Unplug and re-plug the printer into the power source to reset it.
  10. Load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 11, 2011 | Lexmark X1150 All-In-One InkJet Printer
Printer and status light flashing - feed not working. Have checked cables.
  11. Try to print again.
Jul 26, 2011 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X75 not working - flashing power and status light - no paper feed.
Jul 26, 2011 | Lexmark X75 All-In-One InkJet Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
Nov 30, 2009 | Office Equipment & Supplies
Lexmark X125 not printing at all.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark X125 All-In-One InkJet Printer
Cover open message
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Jul 20, 2008 | Lexmark X3480 All-In-One Printer
Lexmark 3400
im looking for the software to run 3400 can you help me get it
Jul 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark 3400
printer screen shows cover open but it is,none buttons will work
Jan 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
k24674
