Question about Dell E196FP 19" LCD Monitor
Dell E196FP lcd screen broke
Lcd screen has damaged ,where i can buy part for dell e196fp monitor & what is the correct procedure to replace it? thx
  • Dell Master
  • 1,183 Answers
Generally the LCD screens are covered under 3 yr warranty. If you have purchased it as a seprate product from Dell. Otherwise it would have same warrnaty as your computer system.
You would end up sepnding more money in repairing the LCD , getting a new one would be a better proposition
Thanks
mandeep
Posted on Jun 05, 2008
The Dell AS501 doesn't seem to want to connect to my Dell E196FP Monitor.
If there is a power connector for the soundbar, it should be on the bottom of the monitor where all the other connectors are located.
Mar 25, 2014 | Dell E196FP 19" LCD Monitor
Tip
How to open up / disassemble Dell E196FP Monitor
On my Dell 19 inch LCD Monitor, E196FPf, there are 4 screws on the back, and you need to pry off the plastic bezel from the front. At the bottom of the bezel are 4 small slots where you can start prying carefully with a screwdriver.
on Nov 23, 2007 | Dell E196FP 19" LCD Monitor
My Dell E196FP monitor flashs colour when computer shuts down and power is still on
my guess would be that the monitor cable is loose in one end or its missing pins have you tried a different cable?
If that doesnt work try to find the correct driver for your monitor that matches your operating system.
Dec 09, 2010 | Dell E196FP 19" LCD Monitor
E196FP monitor brightness controls do not work
It an happen due to moisture, Temp solution unplug the cables and take it near a light to just give a mild heat and then reconnect.
Feb 19, 2010 | Dell E196FP 19" LCD Monitor
Display off 90 degrees
check the buttons on the front ..there should be one to change that back
May 02, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
My dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
Mar 15, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
I cannot install Dell E196FP monitor properly - resolution poor
The problem is you don't have the display adapter driver installed (Video Card)
You can net that driver at support.dell.com
Jan 25, 2009 | Dell E196FP 19" LCD Monitor
I downloaded a zip file to update my video driver, it contains e196fp.cat, e196fp.icm, and e196fp.inf, can you tell me where I should place these files in my hard drive?
Go into Windows Explorer. There is a folder under c: \Windows called Drivers where all the drivers are stored. You may have to change the file types, because it is a hidden file and will not show up normally. When you open up Explorer>Click on Tools>Folder Options>View Tab>little circle that you unclick to see hidden files. Just don't forget to click it back after you are done. Good luck.
Jan 04, 2009 | Dell E196FP 19" LCD Monitor
Dell E196FP resolution 1600 x 1200
LCDS only have a fixed resolution (optimal) so you either need a new lcd that supports the 1600X1200 resolution or use a crt (bulky monitors)
Jul 17, 2008 | Dell E196FP 19" LCD Monitor
Dell E196FP TCo99 Monitor screen problems
The screen colour changing is apparently an auto test procedure on the monitor and was prompted by a fault with the monitor not automatically shutting down when the computer is shut down. The settings on the monitor have been adjusted to rectify this and the problem is now gone.
Apr 06, 2008 | Dell E196FP 19" LCD Monitor
Dell E196FP 19" LCD Monitor Logo
95 people viewed this question
Alun Cox
