Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Won't read unfinalized discs recorded on it
I have had this unit since Christmas. It has worked fine but now won't read unfinalized discs I recorded on the same unit. It reads blank or finalized discs just fine. I called Panasonic and they are sending me a disc to put into the player that might help "reset the software". Any other ideas out there how to fix this until the disc arrives from Panasonic? Thanks!
  • portobello Jun 14, 2008
    have similar problem.. discs are suddenly playback only, even blank ones.. doesn't read discs I just recorded on it... will try to contact Panasonic about this software problem? do you have hope for that?
  • Steve Dave
    Steve Dave Nov 12, 2017
    This is the answer to alk your questions:
    New Friend:
  • 101 Answers
Clean the lense of your dvdplayer.
Posted on Aug 09, 2008
Problem Pioneer DVR-520H
your lens needs to be replaced.
Jan 27, 2008 | Pioneer DVR-520H DVD Recorder
Cd recorder won't read blank cd
If it is a older CD Recorder, You have to use disc,s that stay music on the label. Disc,s for burning music from a computer will not work in them,
Dec 04, 2012 | Tascam CC-222mkIII CD Player / Recorder
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Hello, Dustin / unsupported discs issue
Hi Brad
Before you attempt to purchase a new lens or a new unit, i would suggest that you buy a "Len Cleaner Disc" to clean your lens, if that doesn't help then you should either repair or buy a new lens.
To repair or install a new lens, you will need a service manual(Let me know if you need one.) Then you can do it yourself.
Please also remember that if you attempt to open or repair the player in anyway, it will void your warranty so i think you should take it to Panasonic and have the unit replaced or refunded.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Kind regards
Dustin Ellse (BearWeb)
Jul 03, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
On my DMR-ES35 Panasonic after perfect operation for 18 months, I'm getting a NO READ message, on disks already recorded on this unit,and several new disks of different makes. The main sympton now is
Same problem. "NoREAD" after about 15 months of moderate usage. Cleaned laser eye thoroughly. Solution is a class action lawsuit against Panasonic.
Jan 21, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
215 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
