Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA R52WH74 The diode and fuse you mention. Where is the best place to pick those type of parts up at? Do they both pull out of the board?
  • 51 Answers
They are solder in parts. The fuse is a 400 milliamp, and you can get it from radio shack. The Diode crosses to a nte 558, and can be purchased offline, or possibly at radio shack.
Posted on Aug 07, 2008
    Genius:
  • 1,030 Answers
I am unfamilar with your original post... can you please tell me the orginal problem... i will gladley help you out.
Posted on Jun 07, 2008
Is there a way that anyone can tell me where the fuse panel is on a RCA Model #: R52WH74 television?
There is one fuse on the AC filter board which is where the power cord is located. Just trace the power cord back to where it plugs into the circuit board on the right side when looking in the rear you will see the fuse located right next to where the cord plugs in on that board.
Nov 16, 2011 | RCA Televison & Video
I have a r52wm24 and have replaced the flyback. The main fuse continues to blow. I have replaced the two diodes on the MID (found faulty), Plugged everything in except the PSD board at MID powers ok. I...
Replace the deflection board you have the same deflection board as the R52WH74 model or the PSB-260 deflection board. You can get replacement deflection boards from www.tvrepairworld.com and also on ebay.
May 26, 2011 | RCA R52WM24 52" HDTV Projection Television
I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
Apr 11, 2010 | RCA HD52W56 52" Rear Projection HDTV
Rca r52wh74 bowed picture and 3 d color
Your convergence amplifier has failed.
There are a few things that usually cause that in that particular chassis design, the most likely one being that you have lost part of the power supply to the convergence amplifier power supply board.
You may be able to repair it yourself if you're good at soldering, and dis-assembly / re-assembly.
Look for a 400ma fuse that's opened near the FBT, and re-solder all the connections in that area. Also check to see if any diodes have shorted around it too.
Good luck.
Dec 01, 2009 | RCA Televison & Video
Where is a the fuse in a rca model r52wh74
On the main power supply board. To get to it you will need to remove the back of the case and locate the power supply board ( follow the power cord to the board ) and it is next to the connector.
BUT, I doubt that is your problem because if the fuse is blown then there would be no lights.
Mar 07, 2009 | RCA HD52W58 52" TV
RCA R52WH74 Convergence Problem
Yes i replace that fluse fl231 all the time at the shop. at least two aweek. and the first few i replaced did the same thing. I would send it back to customer and i would get a call that the set had malfuctioned again and convergence gone. It was determined the reason this fuse blows is bad conections on the flyback transformer. The flyback is the big black component with the red wire coming out of the top. if you examine the connections on this component there will more than likely be a ring in the solder. this is caused by the manufacturing process known as LEAD-free solder. THis cause oscillations in that cuicit. like turning it of and on really fast. this is a very small fuse and cant stand up to this. so when you replace this fuse just simply RESolder these connections apply a little amount of solder to these connection. i am confident this will fix your problem.
Sep 10, 2008 | RCA R52WH73 Projection Television
Rca r52wh74 convergence option gone 3d ish picture
FL231 its the center micro fuse near the flyback Dp231 is on that same board
Sep 06, 2008 | RCA R52WH73 Projection Television
RCA R52WH74
Dear Video77301,
Good Day greetings from me. Please verify or be specific about blinks. 1 LED blink then 9 blink code. I this the number of times ? or 1 and 9 appear? If so pls. check the error coding in your Users' Manual, it is found in the Troubleshooting Pages..Then give us the instruction of each number.... If your set is newer,then you have your warranty, call the store where you purchased. This kind of problem might be in the Stand By circuits , an IC or Microcomputer chip is defective....
BEST RGRDs,
Eriez
Jan 12, 2008 | RCA P52937 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
