Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Emerson flat screen tv with red stripe
Emerson flat screen TV 20 inch has a red/pink stripe running north south through screen. Shows even when playing VCR tape. Any thoughts?
  • Emerson Master
  • 5,568 Answers
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
My led emerson 32 inch flat screen will not power on manually even! red light comes onand flashes 5 times then the red light just stays a solid red and the tv never powers on......nothing! tried 2 ways of...
It has gone into safe mode as an internal fault has been detected you need to take the back off to repair or replace board's up to and including the screen
Aug 15, 2017 | Emerson Televison & Video
What could have gone wrong with my Emerson flat screen tv that would cause
You could have a Power supply problem or either the Horizontal or Vertical Control amps are faulty. If you are not Electronically capable or trained, rather take it to an expert as the removal of these two Power Modules is one hell of a job to remove and you could damage the circuit boards and Printed circuit.
If I am correct, in your case the Power modules are STK975-811A as they are commonly used in flat screen TV's.
Jul 31, 2014 | Emerson Televison & Video
My emerson 20 inch flat screen tv is encased in a dog house for outdoor use. I can't get to the back to see the model number and I want to buy a remote control for it. Is there a universal emerson...
You should be okay just buying any generic universal remote. Any remote requires programming to work with a specific TV, but universal remotes are easily programmable. The instructions included with the universal remote will detail how you program that remote to work with your TV (usually along the lines of simply putting it in programming mode, and pressing the power button until it turns your TV off, and then locking it in)
Mar 23, 2011 | Emerson EWF2006 TV
How do I hook up my Wii to my 32" Emerson lcd hd tv? I have my dishnetwork satellite hooked into the dvd player and it's hooked up to the TV. On my remote I don't see a "game" button like my older Emerson...
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
May 04, 2010 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Mar 26, 2008 | Televison & Video
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
2,242 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
