Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Anonymous Posted on Oct 19, 2010
Error message ink absorber full - Canon PIXMA MP160 All-In-One InkJet Printer
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Oct 19, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557581
Points
31058
Take the printer to a qualified technician, for replacement of the "ink-absorber" unit, and a "reset" of the printer (it has "calculated" when it is full -- unlike the gas-tank in your automobile, there is no actual measurement of the percentage-full status) to indicate that the new absorber is 0% full.
Testimonial: "That's what I was afraid I'd be told. These printers shouldn't need servicing! Thanks for the answer."
Canon MG5350. How to solve error 5B00 on this printer please.
Question edited for clarity and Capitalisation.
When checking the Printer Status, the message "Ink absorber full, error code: [5B00] or [5B01] appears. This error occurs because the waste ink absorber is full. When the ink absorber is full, the waste ink counter value (D) reaches the maximum value (D=100.0).Apr 20, 2021
How to repair Canon MG5300, MG5310, MG5320, MG5330 ...
Videos to fix and clear the code.
https://www.google.com/search?q=error+5B00+on+Canon+MG5350+printer
3answers
Suport code 1702 pxma i cant print
Hi Rolando,
This error relates to the ink absorber being almost full. You should be able to press ok and continue (unless you've already done that in which case, the ink absorber is probably full). http://canontechsupports.blogspot.com.es/2014/09/how-to-fix-error-1702170317041715e08-in.html
2helpful
2answers
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
1helpful
2answers
Ink absorber full so printer wont print
yes, printer wont print and see screen message
Use this method below with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Use MPTOOL to reset waste ink absober full on pixma mp160.
Download your Mptool first http://www.ziddu.com/download/8524406/MPTool.rar.html
Download manual guide how to use Mptool on pixma mp160.
http://www.ziddu.com/download/8525856/mp160manualguide.pdf.html
Hope this can help......
2helpful
2answers
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
9helpful
Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
here are the error codes for your printer
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
15helpful
3answers
Canon MP145 Ink Absorber Full Problem.
I got on error message when started to print.
It’s kept happened and message dialog box “The ink absorber is full” occurred.
Mine is Canon MP145.
Can somebody please help me , on how to fix this problem !
tq
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
old marine
old marine
ZJ Limited
ZJ Limited
