Question about Acer Aspire™ T180 PC Desktop
Pc won't power up
My pc won't power up
    Genius:
  • 2,785 Answers
Plz check with new powersupply, if still the problem persist then your motherboard may be damged
Posted on Jun 06, 2008
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
After relaceing my motherboard dell d630 won`t power up
Double check your pluge and sockets plus if the motherboard is not the original type, check the processor and chipset match.
Nov 24, 2013 | Dell Latitude D630 Laptop Computer PC...
COMPUTER WON'T START
See if power supply fan is running. If not....the power supply is bad. Also...see if there are any lights lit on the Motherboard. If not....the power supply is bad. You can pick one up on ebay pretty reasonable. Hope this helps.
Feb 02, 2013 | Dell Inspiron Computers & Internet
Shut off won't turn back on
how long have you waited since it shut off? it may be overheating. if you've waited for a while and it still won't power up, you may need to test the power supply. if you don't have a power supply tester and most people don't you can remove it from the case and take it to any pc shop. they may charge you a couple bucks but most shops won't do that. if it's bad it will need replaced obviously, if it's not let us know :)
May 06, 2012 | Dell Vostro 320 Desktop Computer
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
My dell desktop won't start. when press the front panel button, computer won't start
check the power connections, if its okay change the power supply or smps
Jul 27, 2011 | Dell Dimension 3100 PC Desktop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Dear sir! my dell optiplex gx 150 won't start when i press the power button but power supply will be start and pc can't give any beep ?
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
Jun 22, 2011 | Dell OptiPlex GX280 PC Desktop
Storm knocked power off late yesterday afternoon....back on this morning. PC won't power up....small green light on back flashing. Modem, router, etc. all back up and running, but PC won't turn...
The first thing to try is to cycle the power. To do this, unplug the power cord from the back of the PC and press and hold down the power button on the PC for 5 seconds. This will completely drain any "stuck" power in the components. Now plug the power back into the PC and try booting. If it still does not come back on after this, then you may be dealing with a blown power supply. You can buy replacement power supplies from your local PC shop for about $50 for a 400watt.
To protect your devices in the future, make sure you have a good surge protector and / or a UPS (uninterrupted power supply).
Regards, Chris
May 25, 2011 | HP Pavilion a350n PC Desktop
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Acer Aspire™ T180 PC Desktop Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
