Question about GE WPRB8050D Top Load Washer
GE wprb8050d0ww washer
Unit stops shortly after starting a cycle. Wait a little bit, start cycle again, fills then stops again. Is this a problem with the control board?
    President:
  • 1,314 Answers
If it fills but not wash at all suspect the pressure switch its the switch where you select the water fill small med large behind that switch will be a dome looking piece with a vinyl hose connected to it try spin drain first if all that works replace the dome switch
Posted on Jun 05, 2008
GE WPRE8100 washer starts to fill and immediately shuts off
I would suspect the washer control panel or timer is the problem.
Jul 25, 2017 | GE Profile WPRE8100G
GE Profile WPRB8050D0WW Top Down Washing Machine from 2/2002 Unit refusing to start, shows 43 minutes. I "assumed" this was an e43 error "excessive drive system brake time", but cannot...
Only have a few minutes before running off to work this morning....but try this
If that does not work, then comment back and I will look for more info tonight...
heatman101
Sep 26, 2011 | GE WPRB8050D Top Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
My GE Profile model WPRB8050D0WW won't start!
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 18, 2009 | GE Washing Machines
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer constantly draining after first cycle
For the machine to keep filling it would indicate that there is a siphoning problem. Check the outlet hose is not running along the ground, it has to rise up then loop back down or the water will just run straight down the drain. If the problem only happens after the first pump out it would indicate the end of the outlet hose is lower than the drum or there is no air break around the outlet hose. (The stand pipe should be larger in diameter than the hose from the machine).
http://selfix-uk.co.uk/under%20sink%20plumbing.html
May 01, 2017 | GE Spacemaker WSLP1100D Top Load Washer
GE WPRB8050D Top Load Washer Logo
336 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
