Question about GE GTS22WCP Top Freezer Refrigerator
GE fridge with a top mount freezer
Compressor motor is running full time. The fridge and freezer are not running. Does it need a cooling charge? Should I turn it off so that it does not wear out the motor? Thank you for information. Rick
  • mbajlop Sep 23, 2008
    We have a GE GTS22WC with the very same problem. It is just over 5 years old. Is there anything that can be done with this unit?
  • robert samples May 11, 2010
    do you hear the fan running in the freezer and is their frost on the back wall on the freezer
  • 943 Answers
HI. thanks for the question. the problem here is that the freezer, is not cold at all . and the compressor is running all the time . sorry , its a failed compressor. thanks the appliance doc. please rate my answer .thanks.
Posted on Oct 07, 2008
GSS22KGPA side by side not cooling
Unplug the unit and pull the relay off the compressor and shake it to see if it rattles. Post back the results.
Nov 27, 2012 | GE Refrigerators
GE fridge not cooling. freezer working ok. compressor fan not working
This is an odd thing to hear. Normally when the condensor fan (}compressor fan) Isn't running the freezer is the one who's temperature rises and the fridge stays about the same. I would strongly suggest looking at the main control board, just for the simple fact that 9 out of 10 times thats the root of the problem
Jun 06, 2012 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
My GE fridge (gss25jemaww) stopped cooling. The light still goes on and off like normal, and the motor works, but the fridge and freezer do not cool anymore. Everything inside thawed.
This tell me the compressor is not running. I would like you to pull the fridge away from wall unplug and remove the cover over the compressor. Feel top of compressor and if too hot to hold hand there keep unplugged and let me know. There are some test I would like you or someone skilled with a test meter to do to eliminate the compressor start components and motherboard. Sea Breeze
Jan 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My 5 year old fridge/top freezer ge profile just stopped cooling, motor running but no cooling
First thing I need you to do is unplug pull away from wall and remove the cover over the compressor. Feel the top of the compressor and if too hot to hold your hand on the top leave the refrigerator unplugged until we can decide if this is the start components or another part like a fan not working all the time. I will send a manual and be available for assistance if you want, Thanks, Sea Breeze
Jan 24, 2010 | GE Profile Arctica Stainless Steel Top...
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
I have a GE model: sts221cmbrww fridge/freezer with ice maker. I quit cooling suddenly. The freezer runs but doesn't cool and the fridge doesn't even run. Where do I start?
Could be the compressor has failed - time to replace the compressor, if the price is right, else you need a new one. Or, you have a leak in the freon, and it needs a re-charge.
Jun 19, 2008 | GE Refrigerators
Freezer and fridge areas both 50 degrees
Assuming you have a frost-free refigerator:
Is your motor-compressor running?
If so, check if you have ice in the freezer section; if so, maybe your defrost thermostat or heating element is kaput.
If the motor-compressor is not running, check in the back of the refrgerator if the defrost time is stuck open, bu turning clockwire the small test screw, with a 1/2inch screwdriver.
Dec 10, 2007 | GE GTS22KBP Top Freezer Refrigerator
GE GTS22WCP Top Freezer Refrigerator Logo
107 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
