Question about Canon BubbleJet i560 InkJet Printer
How to dismantle the canon i560 cover
Can someone please tell me how do I dismantle the Canon i560 cover. The ink cartridges are jammed to the right side of the printer and I want to see whether something is holding it there. I have tried all the trouble shooting techniques but they have failed. Thanks
  • Andre0007 Jun 08, 2008
    I have finally solved this problem and corrected the printer fault.
  • Rodders3 Jun 13, 2008
    Yes. I need to dismantle the printer to replace a spring that popped out that maintains the appropriate pressure on the feeder spool
To open the case, there are 6 slots holding the top cover in place. Insert a flat blade screw driver into the 2 slots at the rear while (gently) pulling the rear end of the cover up. Do the same thing for the 2 side slots, again (gently) pulling(prying) up the cover. Then, remove the 2 side (decorative) covers by (gently) rotating the rear portion down of each downward. They are held in slots by 2 plastic hooks and in front (the wrap-around part) by a tab. Once they're removed, the 2 remaining slots can be reached. Use the screw driver to pop up the front part of the cover. Then the interior of the printer is exposed.
Chas.
Posted on Jun 21, 2008
Small piece of paper can not be found, which the jamming the printer, someone in forum recommends to unzip the printer. May someone please tell me how to unzip the printer.
By unzip, i believe you mean dismantle the printer. Dismantling the printer can (and most probably will) void your warranty. So please consult either Canon themselves or where you bought the product from.
However if the warranty of your device has already ended then remove the screws of the panels one by one, removing each panel and placing the screws with them so they don't get lost or mixed up. Make your way to the cartridge carriage and try to get them to the center for easy removal. After which inspect the roller or carriage for any small pieces of paper that may be jamming the carriage. Remove if found, otherwise try using canned air to blow at the most probable places where the paper might have gotten stuck.
Proceed to re-assemble the printer and try to see if it works. If it does then great, otherwise please go to your nearest canon certified repair shop.
Mar 20, 2011 | Canon PIXMA MX310 All-In-One Printer
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
Printer print nothing or blank
Please these and try to clean the print heads of the cartridges manually:
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Apr 02, 2009 | Canon BubbleJet i560 InkJet Printer
Cannot remove the print head from canon i560 printer
try this - open cover on printer
on the right side of the cartridges is a grey arm - lift it up
remove all ink cartridges.
then remove print head.
Mar 04, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print properly after ink reload
try to clean nozzels and run the alignement utilityt.
Jan 21, 2009 | Canon BubbleJet i560 InkJet Printer
Changing cartridges on Canon i560 printer
you can download your user guide or instruction book here
Apr 05, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
825 people viewed this question
old marine
old marine
