Question about Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5520-5334
Mouse pad and 3 buttons not working at all. Went to control panel/mouse and tried applying different settings but it still doesn't work. I am having to use a regular mouse via usb port. Hoping someone might have a solution. Thank you. I am Acer Aspire 5570Z, after some weeks of use, the mouse pad is not working properly. It moves by itself. Since then I have been using a expeternal mouse via usb.
I already tried to set up via software. Since the I disabled it.
Is there any solution?
  • Anonymous Feb 24, 2009
    I have the same problem, I can not use my mouse or the buttons what so ever nothing budges an inch and I too have to use a regular mouse...My warenty just ended and am wrokding how to fix this issue as well.
When u get to the pdf pg. n seclet the driver u want dont save it, select instead to opon n run. it will unzip all files, then look to the left of the page where the files r listed n select w ur mouse to extract all files. After doing so it may appear u r doing the same thing twice but the result @ the end will show the launch exe. icon which will then go thru a proper installation, done.
Posted on Jun 28, 2008
    Guru:
  • 377 Answers
Hi dear
try to install "synaptics pointing driver" from acerpanam.
Posted on Jun 05, 2008
My touchpad is working only as a mouse, the tapping is not working..why is that ? I have an aspire 3680 mouse work and the 2 click buttons too only tapping is not working. I have check all drivers and they...
1. Go to control panel
2. open mouse options
3. click the device settings tab and you should see your touch pad as one of the devices.
4. Make sure your touch pad is highlighted and click the settings button
5. one of the options is tapping, and you can enable it here
That should get your mouse to click on touch pad taps.
Good Luck!
John Vickers
Aug 13, 2011 | Acer Aspire 3680-2682 Notebook
Once a mouse was attached the Acer Aspire 5532 touch-pad no longer works. When the mouse is disconnected the touch-pad still will not work. I do not see a toggle button to use to toggle between the mouse...
HI Diane,
Since you haven't provided the Windows Operating System version (XP/Vista/7 or other?), I'll have to provide the general scope of what you should try.
1. Go to the Control Panel and open up your Mouse section
2. Look through the different tabs until you find an option to either "Enable" your touchpad, or one that says the equivalent of "Disable Touchpad when external mouse or device is connected"
The idea is to accomplish your aim by working with the mouse settings provided for your system. Good luck and go easy on the "blue thumb". Please provide more specific information before a negative response.
Thanks
Aug 29, 2010 | Acer Aspire 4520-5582 Notebook
Acer Aspire 6920: Broken Keyboard & Mouse Pad
open your laptop keys with nail cutter and see any problem is there
Apr 25, 2009 | Acer Aspire 1640Z Notebook
I want to disable the automatic zoom on the computer mousepad.
ACER ASPIRE (MINES 5735 )
DO THE FOLLOWING AND THERE BE NO MORE FRUSTRATING RANDOM ZOOMS.
step 1: Go to CONTROL PANEL.
step 2: under hardware and sound select MOUSE (mouse properties box)
step 3: select the DEVICE SETTINGS TAB (at top right)
step 4: select SETTINGS.
step 5: select the +box next to POINTER MOTION, then under momentum select PINCH.
step 6: DESELECT ENABLE PINCH.
step 7: press apply and ok.
Mar 14, 2009 | Acer Aspire 5735 Notebook
Mouse pad button is pushed in
start ------ control panl -------- mouse ----------properites-------Buttons--------- Switch primary and secondary buttons ------------apply----------- ok
Feb 10, 2009 | Acer Aspire 3690-2196 Notebook
Acer 3500 mouse touchpad totally frozen
have you tried updating the driver
or go to control panel and mouse and check the settings in there
does your laptop work with a normal mouse
Nov 19, 2008 | Acer Aspire 3100-1405 Notebook
check to see if it was locked press fn and F7 to toggle between lock and unlock of mouse pad functions.
May 31, 2008 | Acer Aspire 5520-5908 Notebook
Laptop mouse
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Mar 15, 2008 | Acer Aspire One PC Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
