Question about Whirlpool GD5SHAX Side by Side Refrigerator
Ice maker not filling with water
How can i manually activate the ice maker so that I can check the voltage across the solenoid valve? Thanks for your help.
  • JohnClark Jun 19, 2008
    The ice maker does not fill up with water.
    Anybody have an idea of what first steps to take?
  • 25 Answers
Take a pice o wire and stick it in dem 2 closest holes and then u will smile
Posted on Jun 19, 2008
Ice maker in Kitchenaid KSCS25FT does not refill. Makes ice cubes when filled manually. How to fix?
When an ice maker produces ice after filling with tap water and then cycles and does not refill with water that is an indication that the=> 2319734 Dual Water Inlet Valve
is defective. Replacing the water valve should get you back into the ice making business. The 2319734 Dual Water Inlet Valve has two sides. One side is for the dispenser and the other side is for the ice maker. When one side goes bad you end up having to change the complete dual valve set. Here is a link to a Whirlpool Ice Maker Trouble Shooting Manual Here is a link to another source for the 2319734 Water Control ValveI will be here should you have questions please ask, Thanks Sea Breeze
Apr 09, 2013 | Refrigerators
GE Side by Side Refrigerator model GSS25jfpa cc. No water to icemaker. Replaced the ice maker and the dual solenoid water valves. Still no water to ice maker? Water to door works fine.
if you can reverse the solenoid valve wire connections,then use the door water fill to activate this valve,but not long as it will overfill the icemaker,this will certify that theres water getting up to the icemaker,then it could be the maker itself not activating the icemakers water valve assy to fill the maker
Feb 01, 2013 | GE Refrigerators
THE WATER NO STOP IN ICEMAKER MOD GSS25SGM GE
Improve the FixYa experience for everyone by voting.
Suggested approach to fixing your problem:
Your ice maker is designed to fill with water for 6 to 8 seconds. Depending on your city water pressure, anything longer than eight seconds will overfill the ice tray and either over flow the ice maker or create cubes that have difficulty ejecting.
There are two basic issues that commonly cause an overfill condition.
  • The first is an ice maker that is sending power to the water inlet valve for a period longer than eight seconds.
  • The next problem which is the subject of this answer is a water inlet valve that is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to imperfections in the valve, it is closing in a delayed fashion.
How to Diagnosis:
The easiest way to determine if your water inlet valve is the culprit, is to install a meter volt meter across the leads of the water inlet valve.
  1. Set the voltage range for 110v.
  2. Manually cycle the ice maker and watch the meter.
  3. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker.
  4. Note the difference in time between when the voltage is cut from the valve and when the water quits filling the ice maker.
  5. If the water shuts off immediately when the voltage is removed, the valve is likely operating correctly.
  6. If this is the case, it is likely that the voltage will be applied to the valve for a period of time greater than eight seconds.
  7. This generally indicates an ice maker control problem.
However, if the voltage is removed from the valve and it continues to fill, the valve is likely at fault. This indicates that due to particle build-up or mechanical failure the valve has lost its ability to shut immediately. In that case, simply replace the valve and it should fix your problem.
May 13, 2012 | GE Refrigerators
No water to ice maker. I want to check the water solenoid to see if it is getting power. I don't have a diagram. is it a 120 volt solenoid? and when does it get the signal to open and allow water into the...
The water control valve gets its signal from the ice maker itself. Then begins the cycle of about six different functions until the ice ejector forks go to the position you see most (home) Then it tells the water control valve to open for about seven (7.5) seconds. You may test the true voltage from the female connection with a OHM meter set to AC voltage. Just have someone press the dispense water control. You can also check each sides coil windings for resistance or OHM's and they should be the same or very close to the same. Use care in the area of the coils and make sure the wires are not wet. One of the two wires for each side may be active even without pressing dispense or having ice maker call for water. Another thing I noticed is that you have two sets of water control valves. The problem is about as much with the Primary Water Control
Valve Part Numbers=> 12544002 and Secondary Water Control Valve => 12002193
as is the=> D7824706Q Ice Maker Module Whirlpool now owns Amana, Maytag, Jenn-Air and Samsung will not let me post their manuals to the public. I can answer your questions as need so If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Amana DRS2660BW Wiring Diagram
Amana DRS2660BW Ice Maker Parts Breakdown
Dec 14, 2010 | Amana DRS2660B Side by Side Refrigerator
Ge s/s icemake floods water
Icemaker generally has only about a 6 second fill time. Most likely a particle made it past the screen in the fill valve and would not allow the internal diaphram in the valve to seal. You can't get to the internal parts of the valve. Replace the valve. Consider an in-line filter installation before the refrig hook up to prevent this from repeating.
Jun 14, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
My refrigerator does not make ice. I have to manually poor water in the icemaker to make ice.My water dispencer works but no water refills ice maker
Hi, The first thing you want to check is the inlet tube where the water spills into the icemaker. Most of the time, the tube gets plugged with ice preventing the ice maker to fill. If there are no blockages, check the inlet valve on the ice maker side of the valve. You can test the valve when the ice maker cycles and see if it is getting 120V. If there is voltage and the solenoid does not engage, replace the inlet valve.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 26, 2009 | Amana ASD2625KE Side by Side Refrigerator
Ice maker not makeing ice anymore
check the output power supply
Jul 07, 2009 | Refrigerators
Ice maker wont fill
Hi, It sounds like the inlet valve needs changes. Could be the plunger inside the solenoid is not lifting to allow water through. If you remove the line going to the ice maker off the inlet valve, try and cycle the ice maker and put the inlet valve over a bucket to see if water is coming out when it gets voltage.
I hope this helps.Please let me knwo if I can assist you further.
Thanks
Vic
May 31, 2009 | Kenmore 53502 / 53504 Side by Side...
Ice maker for Kenmore model 532343 not working
Does your water have minerals?
Faulty Water Valve
Your ice maker is designed to fill with water for 6 to 8 seconds. Check to see that the ice maker is not sending power to the water inlet valve for a period longer than what you unit is designed for. Does your water have minerals?
Also check to see if the water inlet valve is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to wear and tear in the valve, it is closing too slow.
Check the timing on the value. Put a volt meter across the leads of the water inlet valve. Set the voltage range to cover the 120v voltage. Cycle the ice maker and watch the meter. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker. Time the difference between when the voltage is cut from the valve and when the water quits filling the ice maker.
If the water shuts off immediately when the voltage is removed, the valve is probably good. Since it was off 10 days the particle build-up on the valve may be the problem since it could solidify. You could try working the valve back and forth or replace it.
If the valve closed quickly then the problem is the valve was opened too long.
If that is the case then you have an ice maker control problem. In that case see if the timing can be adjusted.
Mar 24, 2009 | Kenmore Refrigerators
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
Whirlpool GD5SHAX Side by Side Refrigerator Logo
48 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
