Panasonic SC-HT740 System Logo
Kerwyn Pope Posted on Oct 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i was hooking up my panasonic home theater with the power on i heard a sound and the power came try power it up went on display f61 and then shut off what seem to be the problem model no.sc-ht740
Anonymous
Level 2:
Sergeant:
  • Expert 198 Answers
  • Posted on Oct 19, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
198
Questions
0
Helped
53531
Points
617
Never hook up theater units with the power on, you need to have the fuse replaced in your unit. You need a trained tech. for this electrical problem.
My Panasonic home theater show me f61 then power went off. I solutions please
f61 is power supply failure.
Time for a repair at an Authorised Panasonic service centre.
6helpful
2answers
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
3helpful
3answers
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
When i push the power button , it clicks, and then displays F61 error and then suts down again, the standbye LED is ON
Hi.
F61 is a faulty Fan.
This is often caused by dust, or by a defective fan bearing.
First step is disconnecting the unit for about five minutes.
If that does not work, the device must be taken apart, to hoover, or to replace the defective fan.
Regards.
19helpful
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
DISPLAY STARTS OK THEN F61 APPEARS THEN STEREO SWITCHES OFF
Probaby needs the output ic. F61 is an output/power error code. But check that the fans turn before trying to replace or taking it in to be fixed. If a fan is not turning you will get F61 too.
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
6helpful
8answers
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
1helpful
Sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
