Question about Panasonic Televison & Video
Servicecodes - Panasonic Televison & Video
I looking for CD player COD for acura mdx 2002
Posted on Jun 05, 2008
I want service code for hyundai HY-21N08 .and i cant adjust the focus on the flyback.
Hi. In almost all flyback trafo's there is a potmeter(knob) where you can adjust the focussing voltage. In some cases however, there is a separate HV potmeter with a connection to the flyback trafo. Normally there are two wires coming out it it. One for the acceleration anaode (25-29 kV) and another mostly thinner wire going to either the CRT socket (4-5 kV), or this divider unit with focussing potmeter. Servicecodes won't help here. These are only for geometry, ctr bias etc.
Nov 20, 2014 | Televison & Video
Bij doorstarten moet ik steeds f1 indrukken en bij het afsluiten krijg ik een blauw scherm met de tekst Hardware malfuction call your hardware vendor for support NMI:parity check/memery parity...
NMI parity error (Non-maskable Interrupt) is generally a motherboard or a RAM issue.
You can try flashing the BIOS to A04 (You'll need to copy the flash executable to a bootable CD or bootable USB drive to run the flash.
Try individual or different RAM modules
if all those do not resolve, issue is most likely the motherboard.
Jul 07, 2011 | Dell Dimension 3100 PC Desktop
I have a servicecode , flo, and the temp. Will not reach the seting i have done
FLO code relates to the correct water pressure flowing through the heater tube. This is a safety procedure in adequate water flow could damage your equipment.
As this code can be one of the hardest to diagnose start by checking that all water suction & discharge slice valves are all-the-way open. If they are okay try clean or replace the filter cartridge.
If the cartridge is new or clean try temporarily run the spa with out the filter cartridge, it could possibly be preventing flow.
If the issue persists you can check that the suction fitting covers are free of debris. If the suction fittings are clear of blockages it is likely that pressure switch or flow switch (depending on your spa model) has failed.
These steps will fix a flo code the majority of the time, the pump is another potential cause but least likely.
Feb 20, 2011 | Qca Spas Majestic Series Grand Cayman Hot...
Panasonic 2330 servicecode
Try 0000. That´s the original operator code of my Panasonic DP-2330 office machine.
Feb 06, 2009 | Panasonic Workio DP-2330 Printer
Dell laptop
That white screen is asking for your bios password. You probably set that the last time you did changes in the bios. If you bought the laptop second hand and the previous owner forgot to give you the password, contact him, or if you can not and/or do not remember the password you set, you have to contact dell, and they can give you a password for it, is no problem for a computer you own. You can chat to them here:
https://support.dell.com/support/topics/global.aspx/support/en/chat?c=us&cs=19&l=en&s=dhs
They're gonna ask you for the original owner information before they'llhelp you though. If you don't have the original information (ie youbought it second hand or off someone), you'll have to do a transfer ofownership. You need to give them the service tag and the express servicecode, that are on a sticker somewhere on the computer (bottom in case oflaptops). Enter the info in the required previous owner fields. Enterall your contact info and submit. It should transfer in a few minutes. Here's the link:
http://support.dell.com/support/topics/global.aspx/support/change_order/en/tag_transfer
Let me know if this helped:)
Feb 01, 2009 | Dell Latitude C610 Notebook
OKI-B8300 MONO PRINTER
H4-01 Heat roller low temp is correct.
You machine has a fuser unit that it uses to bond the toner to the paper, it does this with  a heater lamp heating a set of rollers that the paper passes threw after it has printed.
Your machine monitors this unit to regelate its temp, your machine is sensing via a thermister and thermal fuse the temp of the fuser unit is not hot enough to enable use, this would mean the heater lamp is blown, thermister is faulty or thermal fuse blown 95% chance it's the lamp,
What one normally does is replace fuser assembly with new this is not a user thing it requires a tec, but if your into it, it is the hi voltage hot bit near paper exit.
Oct 30, 2007 | OKI B8300 Laser Printer
Televison & Video Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
