Question about Maytag Performa PAV2200
Stopped mid-cycle Maytag Dishwasher. Running fine then stopped mid-cycle. Now nothing. Checked circuite breaker and GFI. Plugged into a heavy duty extension cord into a circuit at the other side of the house. Nothing!
  • 1 more comment
  • Anonymous Jul 29, 2008
    Maytag Jetclean Dishwasher EQ Plus M# MDB9150AWQ stops mid cycle. We have tried resetting (delay/resume once) and Drain off twice). Nothing. We have tried turning off and then on again after several minutes the circuit breaker. The code lights blink and nothing. The only cycle that works properly is rinse. Please advice.
  • yuriam Jan 19, 2009
    mdb9150awq stops in the middle of the cycle.
  • eric bosman
    eric bosman May 11, 2010
    brand and model number please
I have the same problem.  Model: LAT2300AAE Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
Posted on Jun 22, 2008
Dishwasher stopped working mid-cycle
Make sure you have power to the unit. Check the circuit breaker.
May 15, 2014 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Dishwasher does not turn on. it is plugged in but
These are just some possible solutions that are worded for general assistance, I'm sure you have checked many of these things but others may not have;
The circuit breaker in the electrical panel may need to be reset. Hopefully it is labeled and will be easy to find without cycling power to everything else in the house.
The dishwasher may be on a GFI (ground fault interruption) circuit. The outlet may have a reset button on it that needs to be pushed or the circuit breaker in the electrical panel may have a built in GFI that needs to be reset.
Many dishwashers are installed with a light switch in the vicinity of the unit that is used as a disconnect. The light switch will cut power to the dishwasher if turner off. The switch is sometimes above the counter and sometimes below the sink.
There is also the possibility of a faulty On/Off button or dishwasher circuit board.
Dec 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Frig stopped running.
Maybe over pulling more amps the the GFCI curcuit can handle. Check all the GFCI plug and verify if there are anything else plugged in. Including hair dryers and / or flat irons.
Sep 02, 2009 | LG Heat cool Window Air Conditioner
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE Dishwasher not working...
Sounds like you have a one of four possible issues. More info to diagnose would be helpful. (age, which mid cycle) If the motor runs when you turn the timer dial than it is a belt/motor pump issue. If the motor does not run than a bad motor start switch or the water level switch. More than likely the motor/pump assembly as this is usually the problem on these models. If newer check with whirlpool the manufacturer to see if it is covered by warranty.
Nov 06, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Washing Machines Logo
631 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
