Question about Palm TX Handheld
WiFi Icon on Palm Tx not showing on taskbar
I attempted to autosync wirelessly to update a program and when I did the palm did not connect. After 3 attempts it rebooted and all data was gone. I did a hard reset but now I noticed that I did not have any wireless icon on the taskbar. I have since done multiple hard resets all to no avail. I am assuming that this is a hardware problem. Can you assist as to how this is fixed.
  • 2,794 Answers
You should try reloading the software back into the TX. In order to do it, you will have to erase your TX memory. Make sure you back up your files first.
To erase the memory press the reset button until the reboot screen appears. Hold down on the power button until the erase memory screen appears. Select yes. Reload software from Palm CD.
Posted on Jun 09, 2008
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ... > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
Can not get fi fi on my tx even though I have been getting it for a year
what is the problem you are facing
pelas explain it clearly
Sep 16, 2008 | Computers & Internet
I have the Palm Tx and I cannot connect to my internet. How do I connect it?
check the wifi signal. if it's not the prob, ask the system administrator for the security key (other wifi requires this), proxy settings (proxy server and port no.)
Dec 29, 2010 | Palm TX Handheld
I am not getting connected with wifi
according to the last firmware update they still do not support SDHC. I have a Palm TX also so I've been keeping a lookout. Sorry!
Jan 04, 2010 | Palm TX Handheld
Have to reset Palm TX to power on sometimes
I have a palm TX and it usually just sits for a minute or two when I use blazer. I have also found out that the pda will always reset itself and it only freezes when it has a lot going on. It stays frozen for a while, but eventually unfreezes. As for the home button, it's probably worn down. My power button and my up button have almost completely stopped working.
Sep 09, 2009 | Palm TX Handheld
WiFi not connecting to cisco router
most likely the Palm "listens" on another frequency.
Make sure your cisco is running the Wireless b standard as that is what the Palm Tx needs.
Mixed mode is another option (b and G at the same time)
Let's say your router is supporting the b standard. Knowing the cisco APs a bit, it is also possible to have a channel selected that an older device cannot see/or it is set for another region (which in fact is the same, as frequency ranges are different for each continent).
There are many tools for WIFI analysis, many are free. They will tell you what your router is transmitting at, etc... withouth having to go into the cisco IOS.
Jan 01, 2009 | Palm TX Handheld
Dropped my Palm TX, IR no longer works
I went to the Palm support website. It seems that after any reset, including a soft reset, the Beam Receive function has to be re-enabled. Follow this path:
  • Applications==>Prefs==>Power
  • Beam Receive==>Off==>On==>Done
For more information:,kb=PalmSupportKB,CASE=obj(14838),ts=Palm_External2001
I also updated the driver for my Palm wireless keyboard.
Nov 25, 2008 | Palm TX Handheld
JPG files
The picture program that comes with the Palm software should be loaded into your Palm.
Do you see an icon on your desktop for it?
Oct 06, 2008 | Palm TX Handheld
Palm TX reboot
What happens when you press the reset button on the back of the TX?
May 13, 2008 | Palm TX Handheld
Palm Tungsten t5 WiFi
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Oct 04, 2007 | Palm Tungsten T5 Handheld
Palm TX Handheld Logo
118 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
