Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Hitachi 43FDX15B Convergence Failed
My 43FDX15B has a failed convergence with the red CRT.
I am amateur level at soldering... but I have repaired a TV before (replaced IR receiver on a Philips 19" TV 15 years ago).
What is required to repair this set?
How difficult is it?
What would a shop charge to do it (reasonable rate)?
What is the TV worth now?
Thank you!
-Terry
    Scholar:
  • 146 Answers
You will need to order part no. CZ01341. This is the output ic. There are 2 of them, replaced them both. The numbers that are printed on the old part will not match the new part, do NOT take this to hart. It is a modification that you are putting in. You should be able to do this your self. I would charge 350.00. The set is not worth much, not working. Maybe 100.00
Posted on Nov 18, 2008
The picture has colored shadows and doubled images. People are doubled shadows are red green purple. I would like to know if it worth fixing the tv is about Ten years old. Thank You
In a nutshell, the convergence ICs have failed. The cost to fix by a service company is likely about $300. You may find someone who does it on the side for around $150.
If you are happy with the picture, you like the tv, then $150 might be worth it.
It is possible to do this repair yourself if you have an electronics background.
Feb 18, 2011 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 43FDX15B distorted picture. The top of screen displays a half circle cirle and the image is distorted within the half circle. The same at the bottom of the screen. The middle of the screen is fine....
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 11, 2010 | Hitachi 43FDX15B 43" Rear Projection...
There are green and red waves on the top and bottom of my screen and the shapes in the picture are distorted. This is on a Hitachi 43FDX01B
Ur convergence it dead.U know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com.Replaced 2 convergence ICS,and all it resistors.Shop will cost u $300 for parts and labors.
Jan 27, 2010 | Hitachi 43FDX01B TV
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
I have a 43" ultrascan 43fd01b the horizontal red and blue are not in sync convergence dose not help
Must change convergence ICS and all it resistors.Must know how to solders?Tries Websites Tv repair World.com,Tv repairkits.com for the convergence kit.
Jan 17, 2010 | Hitachi 43FDX01B TV
Hitachi projection TV - video is in 3d rainbow
This sounds like a convergence circuit problem. Your set has two convergence IC chips (integrated circuit). One is for the red CRT, the other is for the blue CRT. This is a common issue with projection TVs. It is not a difficult repair if you have any experience with electronics and soldering. Both convergence ICs should be replaced at the same time. The part is IC (STK394-160E) and is available for around $36 or less. If you have a shop fix this they will likely charge $300-$400. If this information was helpful or if you would like to know how to do this repair in more detail post back on this thread. I would be happy to walk you through it.
Dec 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Loss of red color and dual images
Ur convergence is dead,U know how to solders?Buy a convergence kit,use what in that kit.ur tv should be back to normal.This website have the convergence kit
Tv repair World.com.
Oct 21, 2009 | Hitachi 57F500 57" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
I Cannot get the red to center on the convergence adjustment.
This is a convergence output IC problem. convergence board would have to be removed -than remove and replace 2 STK IC's and check the surrounding resistors.
Sep 26, 2009 | Hitachi 43FDX01B TV
Double IMAGE of RED
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 14, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
164 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
