Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
Whirlpool Dishwasher Heater Element
I looking for installation instructions to replace a heater element for a Whirlpool Gold Dsihwasher GU1200XTLQ0.
  • rrwjr Feb 20, 2009
    I have the same problem for a black dishwasher - I ordered the parts from Whirlpool but there are no instructions with them. Did anyone help you? rrwjr@everestkc.net
  • 3 Answers
Service manual for gu1200 and 1500
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Posted on Jun 12, 2008
The dish washer starts to fill then stops and starts again then stops and the red light blinks on and off
Does it blink seven times, pause, then seven times, pause, seven times, etc. ?? If so you may have a bad heater element. Or the water temp into the D/W is not hot enough. Most machines require at least 120 degree water to work properly. Take a close look at the heater if it looks ok you'll have to check it and the heater circuit with a meter. Turning the breaker off for 7 to 10 minutes will reset the control board but wont fix the heater of course. Good Luck
Mar 12, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Heating element is white hot back by the connectors
the heating element is shorted to ground at that point and must be replaced.. it is not safe to use it this way.. usually that will trip a circuit breaker .. if it doesnt then you might want to have someone check to make sure the correct breaker is used (in your fuse box) ... if it hasnt already done so, that fault can damage the controller and seals where the heater goes thru the tub .. a new heater comes with new seals but not with the parts required to fix the controller if thats been damaged ..
Oct 04, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Is heater element bad
Does sound like the element is bad, confirm with a multimeter, should see 120v across the element terminals, if voltage is present check for continuity of the heating element with the power off, no continuity equals bad element.
Feb 23, 2009 | Whirlpool Dishwashers
Replace Heater Element for Whirlpool Model GU 1200XTLB1 Dishwashr
Look inside the dishwasher to see where the heating element terminals are. If they are in front you might be able to change it but if the element is in back, you will need to have the dishwasher pulled out to install the element.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
Nov 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Heating element not coming on?
with a flashlight you can perhaps see far enough under the d/w, the heater leads plugin in the very back of machine, perhaps one of thje wires fell off during shipping/ installation. if not yoyu can removethe wire and checl heater for continuity, it should have continuity through heater. if not replace heater
Apr 04, 2008 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dishwashers does not dry most dishes even on longest cycle?
make and manufacture would be helpful in trouble shooting for you
Mar 10, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
540 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
